2007 A/C odor.
Old Sep 23, 2010 | 09:51 PM
Em Bee Lover's Avatar
CL550 1976 450 SL
2007 A/C odor.
I live in a clime where the temps wildly ride up and down. I can go three weeks w/o using a/c and then need to. After a couple weeks of no use, when turning to a/c, there is a distinct smell of "stagnant water or musty basement" coming out the vents. Anyone else have this?
When a/c is used often, it is basically not an issue. But, the smell/odor is distracting, to say the least. Not foul "sewage" or similar, but "foul".
A/C and open sunroof minimizes, but the smell seems to be due to water residing somewhere and not being eliminated.
Anyone else experience this?
Any advice appreciated.
Thanks.
Old Sep 24, 2010 | 08:29 AM
IDriveAnM5's Avatar
'10 S550 4Matic, '06 BMW M5
Have you had your cabin air filters changed recently? I change mine at the recommended intervals, and I will also go long periods without running the air conditioner. But, I have never had any odors come out of my vents. Still smells like a Mercedes-Benz!! :-)
Old Sep 24, 2010 | 09:51 AM
emilner's Avatar
S560
Change your a/c filters to start with, that stopped the musty oder coming from my vents. I would also not shut off the a/c compressor (if you can even do that on an S). Many cars you can shut off the compressor to save on gas. The problem is the compressor not only cools air but also removes moisture...
Old Sep 24, 2010 | 11:04 AM
RoundTheBenz's Avatar
SL550 Designo Crystal & Red Interior - SL55 Silver & Black Interior - E550
I just purchased an 07 221 and have the same issue. I also had the same on a previous vehicle (220). First one was taken care of under warranty, new vehicle is in the shop now getting done. Will let you know if warranty covers that also.
Old Sep 24, 2010 | 03:57 PM
BootyHunter57's Avatar
2007 S550 Designo
mine has a weird smell aswell as soon as I turn on the AC
where are the cabin filters located?
Old Sep 24, 2010 | 05:59 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
You might have leaves or something obstructing water drainage. Check as much as you can on your own otherwise a dealer visit might be required.
Old Sep 24, 2010 | 08:51 PM
CL550 1976 450 SL
A/C odor
Thanks for jumping on this. I thought maybe I was being "picky". The bottom feeder part of me uses the old "econ" setting, due to perceived mileage drain of the compressor running. Thus, that may be a factore. I strive for current maintenance, so filters have been changed according to schedule. I haven't checked for blockages. If anyone has experienced this and done a specific fix, pls. fire away.
Old Sep 25, 2010 | 12:51 AM
JonMBZ's Avatar
06 C55, 09 E350
You probably need the a/c system disinfected the dealer can shoot foam through the system to clean it out. Also change the combination filter.
Old Sep 25, 2010 | 12:06 PM
2007 S550 Designo
Where would the combination filter be located? Just to know of course
Old Sep 25, 2010 | 06:34 PM
emilner's Avatar
S560
I would recommend you never run the car with the compressor turned off for an extended period. That will certainly cause a musty smell in no time. Next thing you know you are going to tell us you put regular in it
The A/C cabin filters are located under the glove box. You need to remove the panel located below the box (it is held in with three screws) then slide the clips holding the airbox together and the filters will pull down. It takes 7-8 minutes...
Old Sep 25, 2010 | 07:34 PM
CL550 1976 450 SL
A.C odor
I get 55 octane at the local farmers co-op? What do you mean, "regular"?
Honestly, I was told years ago by a tech, as I have driven Benz since '89, use the "econ", as it's a mileage drain (2-4 in city; why waste if not relevant/AC needed?).
The odor issue was not there in my S430 using econ. But, I will accept your advice.
Thanks, mostly, for indicating the cabin filter location and r/r time. I don't mess with mntce. as I have a tech do it when scheduled.
Regardless, I love the forum and appreciate your input.
Old Sep 26, 2010 | 01:45 AM
nitinopp's Avatar
bicycle
Had to get the filters replaced and have a UV treatment.
Old Sep 27, 2010 | 03:23 PM
S5502007's Avatar
S550 2007
I had the exact same issue with mine and changed the AC and cabin filters...the smell never came back.
Old Sep 28, 2010 | 11:57 AM
I can confirm that the whole system was disinfected and it was covered under warranty. Now no more smelling of old socks! Hope you get the same experience at your dealer.
