2010 Does Not Have Fog Lamps, Am I Correct?
Old Sep 29, 2010 | 06:35 PM
josephpampliega's Avatar
15 MB Sprinter, 14 MB S550, 08 Smart Fortwo, 04 Dodge Sprinter, 87 MB 190E 2.3-16
Hi All,
I am in the procsess of doing a full 2010 S63/S65 cosmetic retrofit on my vehicle but ran into a functionality issue while wiring the 2010 headlamps and LED DRLs.
Problem is I need front foglamps and from doing comparisons on wiring and switches between 2007 and 2010, I realized the 2010 does not have any. See pictures.
Are the LED DRLs suppose to be bright enough to take the place of the halogen foglamps? For sure the headlamps are not sufficient as I have compared old and new and the beams are the same.
Any response would be appreciated as this would be a problem in the driving conditions I encounter.
Attached Thumbnails 2010 Does Not Have Fog Lamps, Am I Correct?-headlamp-switch-2010.jpg   2010 Does Not Have Fog Lamps, Am I Correct?-headlamp-switch-2007-2009.jpg
Old Sep 29, 2010 | 08:12 PM
hyperion667's Avatar
2012 CLS63
!! is that left button for nightview?? if it is, that's a sweet button.....
Old Sep 29, 2010 | 11:14 PM
steveb9771's Avatar
2007 CL550
It appears that fog lamps are an option, See the 2010 owner's manual at
http://www.mbusa.com/vcm/MB/DigitalA...10_s_class.pdf
Old Sep 30, 2010 | 01:14 AM
Diesel Benz's Avatar
I assume it is the same in the use with the facelift 221 (or W212) as in Europe, with intelligent lights the fog lamp feature is implemented with an adaptive beam from the actual head lamp unit. A car with standard head lights would have traditional fogs.
It really isn't straightforward to swap the lights.
