Key Battery Replacement
Old Oct 11, 2010 | 12:58 PM
Protools's Avatar
S550
Just got the warning showing up on my screen that I need to replace the battery in my keys for an 07 S550. Called the dealer they told me it was about $20 bucks per key. I'm wondering, is it just a watch battery? and also is it hard to put the new battery in?
Old Oct 11, 2010 | 01:09 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Please read your owner's manual for instructions. Or in lieu of this you may search MBWorld.
Old Oct 12, 2010 | 01:57 AM
steveb9771's Avatar
2007 CL550
The battery part number is CR2025.
You need two of these per key.
They can be purchased for under $2.00 each
You get a package of 5 for $6.89 with free shipping at http://www.batterybob.com/category.asp?cat=9027
These are the same batteries the dealer sells. The only difference is the outer package which says Mercedes. The batteries are marked with the name of a major batteries are marked with the name of a major battery manufacturer.
It is a little tricky to get the key fob open to replace the battery. Follow the instructions in the owner's manual carefully. You may have to use a little force to get access to the battery. I has to put a string through the key ring hole and pull to get it open while inserting the key as shown in the instructions to cause the compartment to open.
