Access to cigarette acc power?
Old Jan 27, 2011 | 08:31 PM
phatisfy's Avatar
S-class
Does anyone know where or how to access the wire to the acc/ cigarette power wire? I"m trying to locate that wire so that I can tap the power cable of my radar detector. Any help is appreciated! Thanks
Old Jan 29, 2011 | 08:36 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
yes, you slide open the cupholder/ashtray door and look for tworubber caps. under that are 2 screws. unscrewthose and pull out the whole cupholder/ashtray assembly and gain access to the backof the cigarette lighter. If you have one of the early interiors that doesnt have the screws present then you need to unbolt the center console and lift the whole thign up to get at the lighter wiring (4 T-30 bolts 2 in front and 2 on the back sides).
Old Jan 29, 2011 | 01:16 PM
egauster's Avatar
S550 4matic, ML350
Phat- does your radar work through the S windshield? I had to go to a grill mounted unit because mine was severely restricted with the radar reflecting glass we have...
Old Jan 29, 2011 | 07:22 PM
phatisfy's Avatar
S-class
Thanks for the info.I will look into that when I get a chance. I have mine tap into a fuse,and I would have to turn it on/off overtime.I hope I can figure this out.
Old Jan 29, 2011 | 07:23 PM
phatisfy's Avatar
S-class
I have no problem with my V1. it is mounted near the rear view mirror where the dot matrix dots are.
Old Jan 30, 2011 | 12:16 AM
egauster's Avatar
S550 4matic, ML350
Oh cool. I have my speed pass on one side and the night view takes up the other side, so i was stuck... Glad it works for you! I loved my V1! Put it in my wifes car when i got the built in. Good luck with the wiring, another way to go would be the power from the install we did with the VIM module that didnt work. There is switched power from that port under the drivers side panel...
Old Jan 30, 2011 | 04:08 PM
phatisfy's Avatar
S-class
I tried that wire...but I don't think it is safe? Because as soon as I connected my V1 power cable to it,the parking brake light went on. And plus that wire is on constantly,so my V1 would always be on.I want it to turn off when the ignition is off.
Old Jan 31, 2011 | 12:01 AM
egauster's Avatar
S550 4matic, ML350
Thanks for the info! Didn't know that!
Old Jan 31, 2011 | 02:22 PM
vaiofan's Avatar
2009 S550V4 Saks Key to Cure
You can also place the detector at the bottom center of the windshield so it rests on the dash. There is a small square (best seen from outside the car on a sunny day) where there is no reflecting glass. From this location, you can hardwire the detector to the car. This is what I did for my Redline.
Old Jan 31, 2011 | 07:37 PM
phatisfy's Avatar
S-class
It is highly recommended that the radar is mounted up high, so that the radar can catch the rear signals.
Old Feb 4, 2011 | 02:15 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
This makes sense in most other cars but the heat absorbing glass goes around the car so signal strength from the rear or sides is greatly reduced to make it almost useless.
Old Feb 5, 2011 | 11:27 PM
phatisfy's Avatar
S-class
My V1 perform exactly the same as my other car, with the V1 located in the exact location.
Old Feb 6, 2011 | 11:41 AM
ima55r2's Avatar
I don't know what your other car is but driving away in my other car from my testing source my V1 lit up like a Christmas tree and in the S at the same location there is a flickering one light. My GL had no reduced detection because it had the OE tinted glass and only heat absorbing at the windshield.
The best test, as mentioned in another thread, is setting up the detector in the car with the windows up and then trying it outside the car.
Old Feb 6, 2011 | 01:03 PM
phatisfy's Avatar
S-class
I have it in my CLK,and in my Acura? Not to mention all my windows including the front windshield are tinted in my S class?
Old Oct 25, 2011 | 12:09 PM
s4play's Avatar
01 S2000, E46 M3, 99 ML320
So for a 2008 S550, the ashtray removal sounds the best way by removing those two screws?
phatisfy: Sweet looking ride, don't see too many S-class modded nicely! Most are just ghetto done like some drug dealer's ride with black windows and ugly wheels.
Old Oct 25, 2011 | 12:15 PM
phatisfy's Avatar
S-class
Thanks. Yes,just tap it to that location.
