Easy-entry/exit feature Question
Old Aug 20, 2011 | 10:31 AM
OMZY's Avatar
Mercedes S350 2007
Hay folks,
I have S350 2007,,as you know for the Easy-entry/exit feature, the steering wheel goes up when you turn the car off, but in my old W220 S350 2003, the driver seat goes back also when you turn off the car. but its not happening in this car
is there anything to do with the programing or something to make the seat thing possible in this car as the old one?
OMZY
Old Aug 21, 2011 | 02:41 PM
OMZY's Avatar
Mercedes S350 2007
Answers please ......
Old Aug 21, 2011 | 10:15 PM
carsnob's Avatar
2007 S 600 / '06 911 Porsche C4S cab
I had a similar problem in my '07 S600 in that the seat wasn't moving back.
The service guy told me it was because my seat setting is back a significant amount in the first place. Hence the test would be to move the seat forward more than you'd normally like and then see if the feature works. If not, then tell your service dept.
Old Aug 22, 2011 | 07:13 AM
hyperion667's Avatar
2012 CLS63
lol!
Old Aug 22, 2011 | 09:12 AM
OMZY's Avatar
Mercedes S350 2007
thanks alot for ur reply, i've done the test and still no response from the seat. will am sure that the seat option is not available, thats why am asking if some programming might help making it possible?
Old Aug 22, 2011 | 05:02 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
Did you make sure the setting in your convenient options was set so that both seats and steering wheel move?
Old Aug 22, 2011 | 06:14 PM
Emauss's Avatar
2017 C300
What he said....
Old Aug 23, 2011 | 04:48 PM
OMZY's Avatar
Mercedes S350 2007
yes I did, and found that only steering wheel is available. so am asking AGAIN if some programming might help making it possible? even if the seat option is not available in the easy-entry/exit feature?
Old Aug 23, 2011 | 04:55 PM
Emauss's Avatar
2017 C300
Ahh. Now I understand. So you want to know if there is a software update that will add in a function that is not there in the existing version but exists in later model cars.
I have no idea. (sorry)
Old Sep 3, 2011 | 08:49 AM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
if yours are not equip with the seat memory adjustment then there is no software that can help you.
Old Apr 8, 2017 | 09:42 AM
philipgsmith's Avatar
Mercedes W212
I have a new S-Class (W222) 350d - 2017 model. I have been plagued with the "Easy Entry" not working on the drivers seat after a few days of ownership. The steering column moves up OK but not the seat. I have reset everything and tried all of the ideas on the forum website. Then reading one post about the seat having to be at least 20% away from the backstop I tried changing the M1 position to a further forward position. "Bingo" - it seems the MB engineers have added another logic process in that if the seat is already well back it does not need the easy-entry mode to operate. It now transpires that my wife had reset the seat further forward on M2 but had also set M1 and then adjusted it for me (being helpful, of course). Just experiment with the memory position you need and reset it a notch forward and save it a few times until "Easy Entry" come into life. Simple!
