My W221 project..
Old Jun 8, 2012 | 03:01 PM
  #301
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Originally Posted by Tobby
Nice (as everything else) What type of wing is this? Where to buy?
You know where...
Old Jun 8, 2012 | 03:17 PM
  #302
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
Originally Posted by Chris The Swede
You know where...
In fact I do
Old Jun 8, 2012 | 06:01 PM
  #303
malahhaor's Avatar
06 Carrera4
Very nice.
Shame your wheels giving you problems with rear brakes.
Old Jun 9, 2012 | 09:20 AM
  #304
rene_gts's Avatar
Looks nice, but a carbon wing on an S class? You seem to put extreme details on your car, but that wing seems so wrong on so many levels. If I were you, I'd at least paint it black
Old Jun 9, 2012 | 01:11 PM
  #305
There will be several more carbon parts on it soon.....You always have to start somewhere.
Old Jun 9, 2012 | 04:07 PM
  #306
LandSeaAir's Avatar
2008 W204
Wow! I have never seen such extensive and well done mods on a car, let alone a 221!
Old Jun 11, 2012 | 05:27 PM
  #307
TDwayne69's Avatar
2012 CLS63 PP
Hey Chris,
Do you know what the additional white tipped connector is inside the drivers side mirror? There's only two contacts on the actual mirror.
Old Jun 11, 2012 | 05:53 PM
  #308
It is if you have the dimming option and pay extra for that type of glass.
Old Jun 11, 2012 | 05:57 PM
  #309
TDwayne69's Avatar
2012 CLS63 PP
Thanks Chris, I figured it was that or for lane departure.
Old Jun 12, 2012 | 06:21 AM
  #310
jambo25's Avatar
S320 - R320 - B200
Question
Chris,
I have the same connection with the wing mirrors except my dimming connection is on the left and I need that cabling (white connector) f
on the right hand side, as I have already ordered the mirror this will not work correct?
Can this be modified to the right hand side?
Old Jun 12, 2012 | 07:11 AM
  #311
I have no clue.These are not made for RHD..But I think it should only be to move the cables to the other mirror and it should work just fine.
Old Jun 12, 2012 | 03:48 PM
  #312
RT2010's Avatar
s550
You've got PM.
Chris - Can you please check your inbox reg. invoice for sills?
Old Jun 16, 2012 | 04:34 AM
  #313
For you that installed the facelift mirrors.......
Try the memory thing firstly in the post below and let me know if it works.
I also checked all the pins now and YES there is a difference on the old and new...
If this is a solution they might have pined them all wrong and differently wrong so best way is just to pin it the way the old are and they are as this:
Blue 1 to 9 white
Blue 3 to 8 white
Blue 5 to 10 white
Blue 7 to 7 white
Blue 8 to 4 Black
Blue 6 to 9 Black
Blue 4 empty
Blue 2 to 3 Black
Old Jun 16, 2012 | 08:28 AM
  #314
Here is a super strange thing...My dipping didnt work on my OEM mirror....So I tried and tried and puched the mirror buttons and the on and off option for the dipping in the comand and put car in reverse dipped the mirror and pushed the memory button 1 and suddenly all works perfectly. Seems this is something you can affect just with the buttons...So strange....
Old Jun 16, 2012 | 08:52 AM
  #315
OH MY!!!!! This is sooo easy.....
Tried this again.... ALL YOU DO IS:
Put car in reverse. Now the little red LED lights up at the mirror buttons. Adjust the mirror to the possition you want it to go to everytime you put it in reverse and then just alpy park again and it goes back. Now you have dipping working.
Old Jun 16, 2012 | 09:38 AM
  #316
phatisfy's Avatar
S-class
Are you sure if I changed the pins. It's going to work? Because I don't wanna get it all mixed up and have my mirror completely stop working?
Old Jun 16, 2012 | 12:17 PM
  #317
rene_gts's Avatar
Does this only work on the left mirror? I had no idea that my car has this option, but I only got my right mirror to dip...
Okay yeah, only right side moves, just read my manual.
Old Jun 16, 2012 | 12:39 PM
  #318
Did you not read my new post?
Old Jun 16, 2012 | 06:14 PM
  #319
phatisfy's Avatar
S-class
I'm talking about the 'memory' option?
Old Jun 17, 2012 | 03:16 AM
  #320
Yeah...Had the same problem some times but it all suddenly worked...I have "your" version of mirror motor in my passenger side mirror and all works fine now after fiddeling with the memory buttons.
Old Jun 17, 2012 | 03:46 AM
  #321
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
I really admire your ambition on changing everything!
I'm in the process of retrofitting the rollos on my R251 and it's quite a lot of work with just those parts. I can't imagine finding all of the parts for all of your conversions!
I wanted to ask, what is the part number for the Harman Kardon logos on the mirror triangles and how do they attach?
Old Jun 17, 2012 | 04:03 AM
  #322
You got PM!
Old Jun 17, 2012 | 11:46 AM
  #323
phatisfy's Avatar
S-class
I just tried what you said, but the mirror still don't work? Every time I put the car into reverse, the mirror just move all the way up instead of down?
Old Jun 17, 2012 | 12:08 PM
  #324
Try a coupple of times...There is nothing wrong with your mirror..i had the exact same problem and I have the same motor so dont know why.
Old Jun 17, 2012 | 12:16 PM
  #325
phatisfy's Avatar
S-class
So this is what I did.
1)Turn on the auto dipping from the command unit.
2)Put the car into reverse
3)adjust the mirror to where I want it to tilt
4)Press "P". But then the mirror just stayed there and didn't move back up?
I have to adjust it to move back up. But when I put the car back into "R" the mirror moves all the way up again?
