S63/S65 AMG bumpers.
Old 02-13-2012, 03:10 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Correct.
Old 02-13-2012, 03:45 AM
rominl's Avatar
16 GL550
then definitely a good time to "skip" the side makers
Old 02-13-2012, 12:12 PM
phatisfy's Avatar
S-class
I would skip the side markers. IMO? It give the car a cleaner look. But if you want to install the side marker light. Then you would need the bodyshop to cut out an opening before the paint it. The drl on this kit, you use the original side marker wire to connect it with the drl.
Old 02-13-2012, 02:35 PM
rominl's Avatar
16 GL550
so the DRL on this bumper setup you can just hook up to side marker easily? wont have any problem as mentioned before with the factory 2010+ bumper?
Old 02-13-2012, 05:58 PM
phatisfy's Avatar
S-class
yes..direct swap
Old 02-17-2012, 10:46 PM
phatisfy's Avatar
S-class
Ok, so i got a chance to test fit the front bumpers today. Fitment was close to oem spec. Only bad thing was that the drl did not work 100%. I will try and get a error-free canceler harness and try later. other wias I'm very impress with fitment and quality for an non oem product. I have the s65 grill but did not install it yet.Here's some pic's.
Old 02-18-2012, 02:16 AM
  #32
What didnt work with the DRLs?
Old 02-18-2012, 06:07 AM
  #33
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Looks exactly like unpainted original one, post some pics after you paint it.
Old 02-18-2012, 08:05 AM
  #34
Now all I want is the Carbon front lip seen in this pic and Im all set. Anyone seen it for sale?
Old 02-18-2012, 09:56 AM
  #35
phatisfy's Avatar
S-class
There was a plug that came with the drl. And I connected it to the fogs directly,but it just flashes. I didn't try and tap it to the side marker lights so I don't know if that would work.
Old 02-18-2012, 10:00 AM
  #36
phatisfy's Avatar
S-class
I don't know how the oem one look. But I doubt anyone could tell? Once I test fit everything. I'll have some pics of the final product. Btw... Is your drl working good with them resistors? I just ordered a set for mine.
Old 02-18-2012, 12:15 PM
  #37
Dont think it works straight to the fogligt. Try the sidemarker instead.
Old 02-18-2012, 01:05 PM
  #38
phatisfy's Avatar
S-class
I will try that next. I didn't have a volt meter to check the +/- wires so I jut left it disconnected?
Old 02-18-2012, 11:15 PM
  #39
WhiteOnWhite's Avatar
s550
i bought that brabus front lip kit for my ride, you have to call in and order it at brabus usa.
http://www.brabus-usa.com/
Old 02-19-2012, 07:52 AM
  #40
jadeethan's Avatar
toyota sienna, S550, Subaru Outback
Chris, if you were to put this on your car, would you paint it or leave it as the carbon fiber look? I like it too.
Thanks.
Old 02-19-2012, 08:20 AM
  #41
Carbon of course since I will also have carbon mirrors and cardon trunk spoiler.
Old 02-19-2012, 08:23 AM
  #42
Arlen777's Avatar
I mean the bumpers are exact same, its just some non-oem bumpers looks different when unpainted, where as yours unpainted looks exactly like unpainted original. Plus the quality and material looks the same as the oem, which is a good thing.
DRLs work fine but the get too damn hot, so as the other member of the forum suggested in my DRLs thread, i ordered a "automatic relay switch" from ebay that is a better alternative. And here is why: 1. It doesnt get hot 2. You connect it straight to the battery 3. They will automatically turn on when you start the car 4. If you want to drive with just DRLs on (without headlights) they will look like 2010 ones (2010 with DRLs on=only DRLs on. 2007 with resistors and connected to fog light switch=DRLs on + small white lamps in headlights are on too). So i go with Relay instead
Old 02-19-2012, 08:32 AM
  #43
jadeethan's Avatar
thanks chris..did you finish your s63 conversion?
Old 02-19-2012, 12:25 PM
  #44
You will se the progress in my thread when it is made...It is winter here now so it will be some weeks before I can continue with the project.
Old 02-19-2012, 12:46 PM
  #45
rominl's Avatar
16 GL550
arlen's method is more involved but definitely the best way to go imho
Old 02-19-2012, 01:06 PM
  #46
jadeethan's Avatar
I think you can choose one of these if i'm not mistaken:
http://www.ebay.com/itm/LED-Daytime-...23486635487273
Picture of the setup:
Old 02-19-2012, 01:29 PM
  #47
C-DiZzY's Avatar
2010 S550
Jadeethan I know Its off subject but what color is your car.
Old 02-19-2012, 01:33 PM
  #48
jadeethan's Avatar
It's andorite grey.
Old 02-19-2012, 06:38 PM
  #49
phatisfy's Avatar
S-class
I just ordered a set. I'll get back with some info once installed.
Old 02-19-2012, 10:54 PM
  #50
Evangeline123's Avatar
BMW
phat are you doing to upgrade your mirrors and do a headlight led conversion as well?
thanks
Quick Reply: S63/S65 AMG bumpers.
