2008 S550 front brake/rotors change please help !!!
, I suspect the pad touching the rotors. I touch the front rotors after driving about 5 min then stop, it is extremely hot, but the back rotors (not changing ) is cold. He told me he did everything right according to his knowledge. Please help me, what should I do? Is this car has SBC? do I need to reactivate something??
Thank you so much for your time. I been getting a lot of help from this forum, love you all!!
.oh, you can also have someone stand beside your car and look at the brake while you roll forward slowly. you "might" be able to see if it's rubbing.
P.S. if your car have SBC then you have to disconnect 2 battery before changing pad. Hope this will help someone... so you don't have to go to this scare and worry like me
you suppose to pump the brake right after you install it to "set" it (push the piston) back but as soon as you turn on the engine, the piston should release until you step on the brake again. it's hydrolic assisted electonically. no matter, good thing is that it drives fine now
and empty ego.
