Help! Removal / Repair Dash Air Vents s550?
Old Feb 27, 2012 | 07:29 PM
new550's Avatar
2015 s550v4
Hello -
I need some help.
Due to an "incident" with a pair of ski's and my teenage son...the details are not really important...grrrrrrr..... I need to disassemble my s550 ac/heater vent in the center of the dash (the one with the analog clock between the two vents. The one on the right side of the clock is damaged, or at least bent. I am not sure how to remove the vent so that I can either fix or replace it.
Can anyone help me with the steps/details on how to go about this dissassembly?
Thanks to all in advance !
Old Feb 28, 2012 | 08:27 AM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
Originally Posted by new550
Hello -
I need some help.
post picture.
Old Feb 28, 2012 | 07:55 PM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
You need to take away the hole wood panel. Alot of screws...
Old Feb 29, 2012 | 09:21 PM
new550's Avatar
2015 s550v4
Damaged Vent Pictures
Here are the picts...vertical diffusers loose and main horizontal one bowed?
[ATTACH]Help!  Removal / Repair Dash Air Vents s550?-damaged-vent.jpg[/ATTACH]
Attached Thumbnails Help!  Removal / Repair Dash Air Vents s550?-damaged-vent1.jpg
Old Mar 1, 2012 | 04:39 AM
Diesel Benz's Avatar
Actually no need to take any holes out of the wood panel.
Old Mar 1, 2012 | 04:44 AM
Did I spell it wrong or?? That is just what I meant...Great pics...Can you get as good pics on how to install lit sills?
Old Mar 1, 2012 | 06:37 AM
new550's Avatar
2015 s550v4
Wow, perfect....do I read this correctly that on the "how to remove trim strip" pdf, the "air nozzle" shown as part number "2" simply unclips and pops up off the top of the instrument panel area...i.e. no screws or bolts to retain, just pressure clips?
Thanks to all...I will take a look this weekend and see if I can get this fixed. You guys are great !
Old Mar 1, 2012 | 06:39 AM
Yes.
Old Mar 23, 2012 | 08:44 PM
new550's Avatar
2015 s550v4
Quick update...thanks to all you guys for the help....I (finally) got around to pulling it apart and fixing it tongiht. It took about 2.5 hours. In the end, did have to take the whole wood trim piece off and remove the center air-vent and clock assembly to get inside, but was able to find all the pieces and reassemble the vent diffusers...all is well !!!!
Many thanks again !
Old Mar 24, 2012 | 02:54 AM
Told ya..
Old Mar 24, 2012 | 11:38 AM
did you document the process of the repair and did you take pictures? if yes would you mind to share?
Old Mar 24, 2012 | 03:56 PM
new550's Avatar
2015 s550v4
Sorry, I didn't think to take pictures, I can give you the steps...it was straight forward...the pdf's from Diezel Benz helped.
1) First, pry up the cover/vent that sits above the clock/vents, etc and in front of the COMAND screen...I inserted a nylon scraper to avoid scratching the wood. I started right above the clock and moved out toward the drivers door. NOTE -
There is a screw centered above the clock once you have the piece loose and are begining to remove, you need to unscrew this before removing the cover from the dash...I didn't see it and broke the tab...doesn't seem to be a big deal however. (This screw has to come out to release the trim piece even if you break the tab to the cover as I did.)
2) Open the covers at both ends of the dash (by the doors)....torx screw holding the end of the wood trim piece in place. Once these are removed, I worked from outside toward center of dash pulling gently until the clips released....these are the same type of clip that holds the end-covers on the dash...just so you kind of know what you are pulling on.
3) Once all the clips are loose, you need to rotate the trim piece toward you so you can unclip the 5 electrical connectors AND the insert clip that holds the cable harness to the trim piece. Most of the connectors are the kind with a small clip to push in while you pull out the plug. The largest one has a light gray clip on the black connector...rotate the gray clip toward the drivers door (counter clockwise) and it will release and extract the connector plug.
4) The whole assy can be removed at this point and you can get to the vent assy, the control panel for the air/heater, and even the analog clock if you needed to.
5) After finished, I just replaced the whole thing by reversing the steps.
Hope this helps?
Old Mar 26, 2012 | 04:34 PM
Diesel Benzhave always been helpful and accommodating to all inquiries, really a great guy and an honest blogger.
Old Apr 21, 2013 | 09:55 AM
Zerocarpileup's Avatar
2008 S63
Does anyone have the PDF on the dash trim removal? I need to get to the clock.
Old Apr 21, 2013 | 10:58 AM
hope this help.
Old Apr 21, 2013 | 08:24 PM
2008 S63
Thank you for the quick response. You saved me lots of trouble.
Old Jun 25, 2019 | 09:42 PM
paulkol's Avatar
ml320
to remove the clock, are the screws easily seen through the grill or does the grill pop off before accessing the screws
