Finally a sub enclosure for our cars - teaser
Nishboo, I took a look at your build and decided to go with the Audiocontrol LC2i for my application. There was actually a user that has an E class Mercedes and posted a review over at Crutchfield. He also made mention of removing the OEM sub to get more bass in the cabin. So once I get the converter I will go for the installation.
Dannieboiz, any other thoughts or ideas? Many thanks for initiating this and to you as well Nish.
Check this video out. Should help you establish an idea in regards to the LC2i being worth your coin. I'm going to give it a shot.
This wouldn't help my amp though since I have a hi/lo switch on my amp that would automatically boost or reduce the signal so it won't clip. I was hoping it would flatten out all the curves tuned by the factory radio similar to the 3 Sixty or Clean Sweep. My gains isn't even more than 1/2.
