Exhaust set up w/sound clip.
Good Job.
Phat - That sounds awesome - pretty much sounds like S65.
Can you provide exact model for SS Mufflers if possible from the shop that put it on. I want to be sure since slight changes can make a significant difference.
If you dont mind, how much did this project cost you esp. labor? I can see it was well worth it for you.
for exact type of stuff ask in shop someone.
I have S550 and i have only changed rear mufflers to an original S65.Also i have tryed without resonator but the car was just too loud and there was lot of rattle sound so i have put back on resonator.Now the sound is great...real deep V8 muscle sound...but still it is a litlle bit too quiet.
You suggest to do the h-pipe.But where?On the engine side before resonators or on the rear side after resonator before rear mufflers.What would i achieve by doing that?Will it be a little louder?
Cuz basicly h-piping is the same like x-pipe but x pipe provides more gentle radius allows for better exhaust gas scavenging, noise cancellation and better balance between cylinder banks.
Thanx.
Thanx.
if you have s550 just change back mufflers to hiflo resonators or non-stock front mufflers ($100-$200 each), than if you have not euro amg-pack remove h-type resonator (it is not h-pipe!), put straight pipes and just add pipe between them in closest place = h-pipe. if it will be to loud to you just add two round hiflo resonators ($50-$150 each) after h-pipe. you will get real badass amg sound only for $1k (if you will add here tips and work).
Thanx.
Thanx.
its not subaru, gtr or mustang gt500, you have luxury expensive car, only you want is just attract some more eyes (mean girls
actually x-pipe and h-pipe are similar for performance. we tested many systems (handmaded) on cls55 and m5 and differences were at dyno +/- 2hp.
better put h-pipe (as x-pipe) (knowing physics) in the closest place between pipes after headers. i only noticed sound difference between arch h-pipe (like most stock amg exhaust have) and straight real H-pipe like stock SLS have too (and stock sl600 r230 too for my surprise). you can find videos in youtube how they speak
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
arch h-pipe after cats on stock sl55 system:
![](https://mbworld.org/forums/attachments/new-s-class-w221/236494d1338099333-exhaust-set-up-w-sound-clip-crossover.jpg)
straight h-pipe on stock sls system:
![](https://mbworld.org/forums/attachments/s-class-w221/236812d1338438774-exhaust-set-up-w-sound-clip-h-pipe_sls_stock.jpg)
better do like on sls system. you can leave resonators, if it will be quiet for you just remove them. with h-pipe you never will have crackling noise like with x-pipe (of course if your exhaust guys have hands)
creating and installing h-pipe in good service place will cost approx $150.
So acctualy i can put h-pipe in the area after cats before resonator....i mean between cats and resonator?I dont want to remove resonators cuz i know it would be too loud like fckn viper or something....
It sounds amazing now but it is just little too quiet.
#32
Our cars already have a H pipe. I have tried many different set up combinations,and nothing sounds right with the H pipe? And w/out an X pipe. The car sounds like **** cause it makes a weird sound. Check my video that I posted and you'll know what I mean.
#33
if you tired to take a photo just find smthg similar to yours.
actually the best way to install gas mixer after cats, just right before resonators, then you'll get "heavy" sound, if you put h-mixer before cats and resonators you'll get similar to amg sound (heavy but muffled). if you wont listen me and put loved by everyone x-pipe, put it only after resonators, just before end mufflers, another way not reasonable for performance. but just forget about this x-****, leave it for c63-tuning-freaks
install h-pipe just before resonators (5-10 cm), after cats, like sls system:
![](https://mbworld.org/forums/attachments/new-s-class-w221/236812d1338438774-exhaust-set-up-w-sound-clip-h-pipe_sls_stock.jpg)
#34
phatisfy, your system is not right way configured, thats why you have no result. even pipe connections are not right way welded. go with h-pipe. and remember that mufflers supersprint, magnaflow etc are just fraud behavior. but the reason can be also in pipe diameter. of course you need minimum 2 inch pipe to get all sound notes
better buy high-flow fire resonators with diffuser for cents and put them instead mufflers (i know its sounds ridiculous, but try it, you will get what you need from such ride) and leave OEM resonators (if you have them separated, not H-resonator), just put H-pipe bro. anyway the question price is really cheap for experiments.
#38
sry, now working
www.youtube.com/watch?v=vgbkXQQs5BA
sorry for quality, it mute a bit after noise become loud, like image become dark cause of light, but you can hear the note.
