Drive Dynamic/Multi-Contour Seat Problem
Old Jul 29, 2012 | 09:06 PM
fstshrk's Avatar
2007 R320 CDI, 2010 FJ Cruiser, CTS-V
I bought a 2008 S550 on Thursday from a dealer about 250 miles away.
While on the test drive, everything worked perfectly.
On the drive home, the drive dynamic/multi contour seat partially stopped working. It looks like the driver side seat bottom, right side air bladder is not holding air. The lumbar support air bladder(s) also seem iffy.
The car is CPO with factory coverage ended only 3 days ago.
Has anyone gotten the seat air bladders covered under CPO? If it helps, I do have the CPO extended coverage up to 135K. I am hoping our dealer would cover this under goodwill since it is only 3 days out of the new car warranty and we are good customers, but one never knows.
I did find two service bulletins that seem to apply to the car with this topic.
We did a 1 hr long test drive and everything worked great.
Old Jul 31, 2012 | 02:46 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
No CPO does not cover seat cushions and the drive dynamic seats in general, only the new vehicle warranty
Old Jul 31, 2012 | 04:00 PM
T.H.Carrera's Avatar
2012 w221
thats gonna be an expensive fix .........
Old Jul 31, 2012 | 05:04 PM
fstshrk's Avatar
Yes it is an expensive fix. The selling dealer is working to help us.
Old Jul 31, 2012 | 05:17 PM
malahhaor's Avatar
06 Carrera4
I believe just a single bladder insert is like 400 bucks? My driver right side deflates. And passenger left side doesn't work at all. I'm holding off till next year to fix
Old Jul 31, 2012 | 06:40 PM
fstshrk's Avatar
The parts alone are 1000.
Old Aug 3, 2012 | 09:54 PM
Em Bee Lover's Avatar
CL550 1976 450 SL
Yep. The "adaptor" as it's called, is costly. The pump could also be a factor, but it's usually a blown bladder, if you will. Seat back bladder is $400 in part by itself. Clearing the faults and it works until software shuts the pump down and then you again get a fault. Saftety measure. A went through the whole deal. PM mean if I can be of help. Good luck.
Old Aug 3, 2012 | 10:11 PM
fstshrk's Avatar
Thank you. MBUSA and the selling dealer are covering the repair. Parts are on order. I expect the repair to be done in the next week or so. I have to say kudos to MBUSA and the selling dealer. The car is superior to anything that I have owned before.
