Someone here must know - camera wiring??!!
There are three OEM BM parts - a camera (A2218200397)- which plugs into a module (A2218708326) that sits in the trunk and then a wiring loom (a2215102710)
There are power and earth cables for the unit(s) in the trunk - I know this as they are not very long at all) and then there is a plug (two wires) plus two wires with pins on the end (see attached)...
Where do these pins and plug plug into - the wiring seems long enough for them to reach the back of the command unit...but I just dont know how to connect them in. One of the pinned wires has 3158 and is gold with clear insulation, the other has no markings but has a silver colour wire inside a clear insulation
I know I'm going to have to pay for re-coding - my car does have 230 - Parking Assistance on it - but I need to keep costs as low as possible - please help!!!!
thanks
Alex
The transparent wire goes to contact cavity 7 on the 20 pin COMAND connector. The screening line goes to cavity 17.
Then you have the interior CAN wires and one to the voltage distributor X30/32.
PM me your email address and I'll send you the illustrated instructions.
its only missing a bit of shielded cable ( if you did everything else already) you can run it up the inside of the centre console
don't ever listen to people on the internet...
FYI if you have the early aluminium camera and the early iPod kit the night assist element of the camera stops working, if you get the ultra rare later ipod kit with a different loom it works again but takes a split second longer to pop up on selecting reverse
