2007 s550.. Any way to install AUX-in? I have iPod kit, but hate it..
Old Aug 26, 2012 | 09:25 AM
nimski62's Avatar
The iPod kit is worthless to me because I like to stream Pandora. Is there any way to convert the iPod kit into an AUX in 3.5mm jack?
Old Aug 27, 2012 | 11:35 AM
jtaudiodesign's Avatar
2007 s550
yes there is. depends on how electronic savvy you are. i did it to mine. the ipod kit is essentially an aux in the way it is set up thus the reason it doesnt work thru the command. you can solder audio and video rca cables into the ipod wires behind the cd/dvd changer which will give you aux input for audio and video ( if you have the video enabled ipod adapter ) the only down side is you cant have your ipod plugged in at the same time as the aux because they are using the same wires. or you could get a rca switcher and have both plugged in. i did this so i could listen to pandora as well. i did mine in about an hour and ran the cables to my center console and it works beautifully. but keep in mind i do car stereo installation for a living. hope this helps
Old Aug 27, 2012 | 03:34 PM
nimski62's Avatar
Wouldn't this technically work?
http://www.ebay.com/itm/251130119983...ht_3605wt_1017
Old Aug 27, 2012 | 03:51 PM
2007 s550
i suppose its worth a shot for 8 bucks. except for the fact that it says it wont work with mercedes ipod cables
Old Aug 27, 2012 | 05:00 PM
malahhaor's Avatar
06 Carrera4
You can geta BT module that connects to the iPod cable in your glove box and you can stream what ever you want. Downside is that you lose phone connection if you have it.
Old Aug 27, 2012 | 06:30 PM
nimski62's Avatar
Yes, but it seems the aux input remains active even if there isn't an iPod connected to it.. If i plug in a playing iPod, the music comes thru the instant i connect the iPod, and this tells me that the input remains active. I am going to try it and I will let everyone know how it went!
Old Sep 6, 2012 | 05:32 AM
nimski62's Avatar
This item turned out to be exactly what I was looking for. It connects to the iPod cable in the glove box and turns it in to a true 3.5mm AUX. It works just as I thought it would even though the listing says it won't work on MBs!
Old May 10, 2013 | 05:04 AM
psumosdef's Avatar
2006 cls500
can someone please post the diy for the 2007 s550 aux ?
Old May 10, 2013 | 05:05 AM
psumosdef's Avatar
2006 cls500
or email it to me at psumosdef@gmail.com
Old May 10, 2013 | 11:28 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Most of the BT streaming modules available present a second BT network. Your phone can easily pair with the MB BT for Phone Integration and the BT AUX device for streaming.
Old May 20, 2013 | 09:57 PM
anton28's Avatar
2023 Rover
So is there a way to stream video from your iPod to you're nave screen?
Old May 21, 2013 | 09:41 AM
Zerocarpileup's Avatar
2008 S63
You need a NavTV module,
http://www.ebay.com/itm/NAV-TV-W221CAM-Kit-Audio-Video-Input-and-Backup-Cam-Interface-for-S550-/330923603933?pt=Car_Audio_Video&hash=item4d0c9577dd&vxp=mtr
Old May 21, 2013 | 12:53 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
what's the name of this item? Trying to look for it but no luck
Old May 22, 2013 | 02:05 AM
anton28's Avatar
2023 Rover
Originally Posted by Zerocarpileup
Thanks!
Old May 22, 2013 | 07:17 AM
malahhaor's Avatar
06 Carrera4
This works perfectly for me. It's a Bluetooth to iPod converter.
Once paired, all phone audio, in my case Pandora or any other internet radio streams to the car when it's set to AUX input. I am also able to skip using controls on steering wheel when cluster is on audio.
Depends on your phone and Bluetooth Software, you may have problems being connected to this and phone at the same time.
http://shop.mobileweb.ebay.com/searc...0&isNewKw=true
Old Mar 27, 2015 | 10:24 AM
mjnapco's Avatar
s550 2007
Would a Bluetooth adapter work?
HI Guys, quick question, has anyone tried or know if a SD card or PC card Bluetooth adapter would work if it was inserted in the mp3 slot of our cars? Would it then be able to pick up the signal from an iPod or iPhone and play music through there. It didn't even know they existed but I did a Google search and I guess they do. Take a look at the links below
http://www.wisegeek.org/what-is-a-bluetooth-sd-card.htm
Amazon.com: Belkin F8T002 Bluetooth PC Card: Computers & Accessories Amazon.com: Belkin F8T002 Bluetooth PC Card: Computers & Accessories
Old Mar 28, 2015 | 11:49 AM
steveb9771's Avatar
2007 CL550
Very little chance this will work since this device requires unique driver software when installed in a computer. Your vehicle does not contain the software to configure and communicate with this card.
