Facelift Completed 100%
Old Mar 23, 2013 | 12:30 AM
  #51
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
Originally Posted by azizblue
what do u mean suprised parts.i try to search it no resault .please explain.thanks
Supressed, meaning you can find used headlights with part #1111, but if you want the same exact headlight from the dealer, the part# will be #2222. There are many of these used headlights with supressed part#s on ebay, and if you call the dealer to figure out what kind they are (like night vision, ASF, etc) they wont be able to tell you, because they arent in database anymore.
Example: My original headlight has part number A1A1A1, and it is broken, so if i go to dealer and tell them that i need "Headlight with part# A1A1A1", they will not have it. But if i give them my VIN# of my car, they will give exact same headlight for my car but it will have new part# A2A2A2
for the ecu units did u buy them new or used .
Used
Hope that helps
Old Apr 3, 2013 | 03:34 PM
  #52
michaelwjoyner's Avatar
2007 S550
Arlen, nice job.
Is that a AMG 2010 bumper. I am totally new, just got a 2007 S550 and I want the same front end.
I was wondering where you got the bumper and grills.
Old Apr 3, 2013 | 07:54 PM
  #53
azizblue's Avatar
2011 s63 amg
call wel.he got everything from a to z 561 316 6865
Old Apr 10, 2013 | 11:40 PM
  #54
Fahad.M's Avatar
s class 500
perfect work , it's really looks great
Old Oct 28, 2017 | 02:55 AM
  #55
token's Avatar
2007 S550 (W221)
Hey guys! Reviving an old thread here, but I just performed the headlight upgrade on my car, as well. I used the following headlights from e-bay:
221 820 57 59
221 820 58 59
...plus the 6x ECUs/ballasts
And I got the wiring harness from Chris the Swede.
Installation was straightforward, but I have a bit of a problem. While the headlights come on (low and high beams) and the turn signals work, it doesn't appear that my active cornering is working anymore. I get a dash error, "Active Headlamps Inoperative."
Any ideas as to what might be wrong?
Old Oct 28, 2017 | 06:26 AM
  #56
Chris The Swede's Avatar
W222 S63L, ML/GLE350
You you need to do alot of coding....Was not the install manual inside box? If not just mail me and I send pdf.
Old Oct 28, 2017 | 10:51 AM
  #57
token's Avatar
2007 S550 (W221)
Hey Chris, I sent you a PM with my email. No, the manual wasn't included.
Coding is required? I thought the whole point of the cable harness was that it was "plug and play" and that coding wasn't required?
I guess I'm almost there; the lights look sweet!
Thanks, man!
Old Oct 29, 2017 | 03:48 AM
  #58
Cables are. Codings not.Need Star Diagnose.
Old Oct 29, 2017 | 08:53 AM
  #59
token's Avatar
2007 S550 (W221)
Ah, ok. Please send me the instructions and I'll try to find someone to do the coding. Thank you!
Old Oct 29, 2017 | 09:06 AM
  #60
berti_00's Avatar
2016 Cls63s AMG
were is the pictures??? i cant see anything
Old Oct 29, 2017 | 02:17 PM
  #61
token's Avatar
2007 S550 (W221)
No pics, yet! lol. Almost done. A piece of road debris destroyed my bumper, so I ended up doing a bunch of work at the same time... Replaced the radiator, replaced the bumper, and decided to upgrade the lights. The bumper needs to be buffed out, and I'm still waiting on the daytime running lamps. Then there will be pics!!
Old Oct 29, 2017 | 03:54 PM
  #62
berti_00's Avatar
2016 Cls63s AMG
I cant even see OP's pictures
Old Oct 29, 2017 | 04:16 PM
  #63
token's Avatar
2007 S550 (W221)
Oh, I can't, either. I just assumed they were hosted on a separate site and are no longer available.
Old Mar 8, 2020 | 06:59 PM
  #64
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
TO DJ_sham -- I just install the Diamond grille in my 2015 ML and like you I had to make some cuts but it worked. My problem is that the Mercedes Star that came on my 2015 is too small for the larger diamond grille. Question
Where do you get the larger star to fit the diamond grille Thanks.
Old Mar 8, 2020 | 07:28 PM
  #65
Joseph~'s Avatar
2008 R320 CDI 4MATIC
FWIW.....you do realize this post started in 2012 last posting was in 2017
Run you VIN at;
www.mbepc.net
Will show all original MB part and part numbers for the vehicle.
Regards
Joseph~
Old Aug 20, 2020 | 04:43 PM
  #66
Luke Walker's Avatar
ML350
Hey Guys,
Can someone help me out to get a wiring harness for the LED upgrade, I currently have the Bi-Xenon.
From what I can see I need these headlights to replace the old ones:
166-906-81-03
166-906-82-03
Old Aug 21, 2020 | 03:36 AM
  #67
Originally Posted by Luke Walker
Hey Guys,
166-906-81-03
166-906-82-03
This is a W221 thread..
