Jack popped out from under car
Old Sep 16, 2012 | 11:25 PM
davesenko's Avatar
2007 Mercedes S550
Exclamation Jack popped out from under car
On my S550, I was jacking my right front wheel off the ground with factory screw jack; flat concrete driveway, chocked wheels, etc. Jack popped out and car dropped to frame. The jack was firmly seated in the jack base of the car.
Jack appears undamaged, but body of car is damaged. The wrecker driver said he had never seen such a case and that I should contact Mercedes.
Anyone have this issue?
Old Sep 16, 2012 | 11:35 PM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
I havent has this issue before, because the moment i saw the original jack i was like "hell no, i am not using that". It looked to dangerous at the beginning. Dont understand why mercedes would make jack like this, especially for such a big and heavy car like an S. You should call mercedes of usa and complain to them.
Old Sep 16, 2012 | 11:44 PM
davesenko's Avatar
2007 Mercedes S550
its very dangerous. It happened instantly and without notice - someone not being careful could get something smashed, or worse.
Old Sep 16, 2012 | 11:45 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
low pro flow jack only.
http://www.northerntool.com/shop/too...6598_200326598
Old Sep 17, 2012 | 04:36 PM
desired_speeds's Avatar
2007 SL55 AMG
I don't dare use the OEM jack. My friend dropped an SL last time he used the stock jack. :S
Old Sep 17, 2012 | 04:57 PM
davesenko's Avatar
2007 Mercedes S550
well now i can add something more. neither mercedes usa in new jersey, nor alex rodriguez mercedes dealer in houston even cares to hear or see the issue. amazingly no concern whatsoever. in fact, i was told 'we wouldn't use the stock jack anyhow, we use jacks with a broader base'. not exactly the answer i would expect from mercedes, maker of one of the finest engineered autos in the world. please spread the word - DO NOT use the stock jacks. never, not even under garage-like conditions, and most certainly not on the roadside.
Old Sep 17, 2012 | 06:43 PM
layzie12g's Avatar
2008 Mercedes Benz E63
I had a friend die recently from his car falling off a jack and squishing his head. Always use a good jack with a good set of jack stands.
Old Sep 17, 2012 | 07:47 PM
MBNUT1's Avatar
2010 E350 4Matic
This is such crap. It it doesn't work on a nice even driveway what are you supposed to do on the side of the road other than call roadside assistance or use fix a flat. I did have my 190E go down of the factory jack but to be fair the was a bit of an incline to the driveway.
You would expect the best jack design in the world to accompany the best car in the world
Old Sep 17, 2012 | 08:23 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Sounds like you need to talk to MBUSA. Someone could've been seriously injured.
Old Sep 17, 2012 | 10:59 PM
S_G7's Avatar
2007 S550V4
Does anybody have recommendations on a more suitable portable jack that could be used to replace the OEM one?
Old Sep 17, 2012 | 11:30 PM
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
great info.
Thanks for sharing.
You would think MB have the best designed jack in the world that works safely.
