s65 diffuser for 07 s550
Old Oct 18, 2014 | 03:32 PM
  #51
Mike5215's Avatar
2016 C300
http://www.ebay.com/itm/OVAL-2010-BE...b20d6a&vxp=mtr
Old Oct 18, 2014 | 09:42 PM
  #52
lbegiss's Avatar
E550 coupe , S550 w221, X5m50d, Cayenne GTS
curious
I am curious to know why is it the one in the middle one that would work for me. and not the other one ?
Why is it like that ?
thank you
Old Oct 18, 2014 | 10:35 PM
  #53
Mike5215's Avatar
2016 C300
thank you
You mean why do you need the tip that goes from a single pipe into dual tips? Because you only have single pipes. The full quad tips are for cars like the S63 and S65 that have a true header-back quad exhaust - two pipes down each side, two through the mufflers, and twin tail pipes. You'd need to buy an actual AMG exhaust for that.
Old Oct 18, 2014 | 10:55 PM
  #54
lbegiss's Avatar
No Mike, I meant there is a single pipe : YES. but one is in the middle, and the other one is on the side : check this link :
http://www.aliexpress.com/item/muffl...689406873.html
Would these work for me ?
Old Oct 18, 2014 | 11:31 PM
  #55
Mike5215's Avatar
2016 C300
Those should work. The actual tail pipe lines up with the outside tip, and the extra tip is toward the midline of the car. You won't be able to tell they aren't true duals without looking under the car. It's the only way to do it without swapping out the OEM mufflers. You may want to consider spending a couple hundred more and getting the whole axle back exhaust. Then you get the sound plus the cosmetic change, and they look like a true quad.
Old Oct 31, 2015 | 12:57 AM
  #56
tchu-'s Avatar
2007 S600
pm'd 604benz!
