07 s550 telephone won't work via bluetooth
Old 11-04-2012, 03:12 PM
gregb1221's Avatar
2007 S550
I synced up my HTC one X via the bluetooth, it says it is authorized and available, but when i try to make a call it says no telephone inserted...Need help.
Old 11-04-2012, 03:45 PM
carboxy's Avatar
07' 911 Turbo, 09 ML63
You need a puck. I suggest look on ebay
Old 11-04-2012, 03:58 PM
gregb1221's Avatar
2007 S550
Excuse my ignorance, what is a puck?
Old 11-04-2012, 04:18 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Do you have something that looks like this in the armrest?
http://www.ebay.com/itm/Mercedes-MHI...365190&vxp=mtr
Old 11-04-2012, 05:04 PM
carboxy's Avatar
generic is right.. look at pic. if you have it then you need a mb puck to connect w bluetooth.. ask away..
Old 11-04-2012, 05:49 PM
marthyh's Avatar
S500
You would need a UHI (pse search forum) and could use a Viseoo 'puck' or an original one.
https://mbworld.org/forums/new-s-cla...ooth-help.html
Old 11-04-2012, 06:29 PM
gregb1221's Avatar
2007 S550
I'm checking or ebay now...does anyone know the MB part number....
Old 11-04-2012, 06:51 PM
gregb1221's Avatar
2007 S550
There are several on ebay but this looks like the correct one. Part Number B6 787 6131 is the black one with MB emblem. Can anyone verify this will work for 2007 S550.
Old 11-04-2012, 07:24 PM
I have one of those silver ones on my R-Class and it came out of my friend's 07 S550. I think the black ones are newer models. To be honest, if I'm given the choice between the silver and black, provided they have the same functionality, I'd go with silver because I think it looks so much cooler.
Old 11-04-2012, 07:32 PM
gregb1221's Avatar
2007 S550
Do they work with all smartphones, I have an android HTC one X. I had heard that MB only worked with specific phones
Old 11-05-2012, 12:15 AM
walt2810's Avatar
07 S550
Have the exact unit that dealer installed when 07 was delivered. Works on the iPhones.
Old 11-05-2012, 09:31 AM
NickCats's Avatar
2018 E300 4MATIC Sedan
Make sure you get part # B6 787 5878
I picked one up on ebay for $160
Nick
Old 11-05-2012, 11:23 AM
If you look hard enough you'll find the 5878 (silver style) for closer to $100 on eBay.
Old 11-06-2012, 11:37 PM
JonMBZ's Avatar
06 C55, 09 E350
6-7-87-6131 and 6-7-87-5878 both work, the black one is newer smaller.
Old 11-18-2012, 12:20 AM
NuMBS500er's Avatar
2014 E350 4matic sedan
07 s550 have 2.1 bluetooth tech., it will syn with iPhone 4, but will not syn with iPhone 4s or 5 they use 4.0 bluetooth tech. Later year S550 that do not require puck will syn with later model iPhones.
Old 11-18-2012, 03:01 AM
I have the 5878 puck (same as for the 07 S Class) in my R Class and it works fine with my iPhone 5. Remember, Bluetooth 4.0 is backwards compatible with older BT spec.
Old 11-18-2012, 06:04 PM
NuMBS500er's Avatar
Latest update, finally got the BT sync with my iPhone 5.
Old 11-19-2012, 03:19 PM
s550148's Avatar
2007 s550
I just got the iphone 5, the older bluetooth device in my 07 worked with my iphone 4 and doesn't work with the 5. If I get the newer puck will it work?
Old 11-19-2012, 03:27 PM
s550148's Avatar
2007 s550
How did you get it to work?
Old 11-19-2012, 04:19 PM
NuMBS500er's Avatar
I have the latest puck 6131 (black), you have to clear the lists of devices on the car command center and also clear the lists on the phone first, then re-synch. The device that you pick is MB System. Good luck.
Old 11-19-2012, 04:55 PM
s550148's Avatar
2007 s550
yeah I have the older puck blue and silver, wonder if I get that black one if it will work?
Old 11-21-2012, 10:18 AM
ULJets's Avatar
07 S600, 09 ML63
The older (2007) puck WILL work with iPhone 5. I just upgraded from iPhone 4 to 5 and at first it didn't work either. What you need to do is reset the puck, I did this by holding down the Mercedes emblem on the puck itself. Then look under the cover towards the back of the puck, you will find a code. Enter that code when prompted and use the same code when synching your iPhone 5. Works perfectly after doing that.
Old 11-21-2012, 02:16 PM
NuMBS500er's Avatar
That's what I had to do too. Except the newer black puck use the universal MB code.
Old 11-28-2012, 01:55 PM
s550148's Avatar
2007 s550
Just had them do it over at the dealership, they got it to work
Old 08-17-2013, 08:21 PM
bking's Avatar
The factory installed cradle on the 2007 S550, and presumably others as well, requires the Motorola phone with MB internal electronics and Verizon as the service provider. This same model Motorola phone is available from Verizon but without the MB internal electronics and will not work with the MB factory installed cradle. For all other phones and service providers, MB offers a blue tooth dongle available from MB dealers. As a general matter, the factory phone in the factory installed cradle is reportedly more reliable and less susceptible to dropped calls and fade outs.
Quick Reply: 07 s550 telephone won't work via bluetooth
