2012 s550 engineering menu
And what comand installed in 2012 cars? They have COMAND Online function?
And one more, eco start/stop need to be activated from diagnostic tool?
bump upi m sure some good hackers can enable to video in motion just with codes those canbus can avoid the warranty
Happy new year to all
Have been searching the web several times for the engineering menu on W221 ,so far no luck.
Afaik vim can only be done with a module , would be great if a hacker could reverse engineer any comand NGT version, I think its too expensive to get a complete comand setup and start experimenting away.
You would basically have to have a spare W221, a lot of specific knowledge and time on your hands , which seems to be quite a difficult combination..
AFAIK they hook something up to the diagnostics interface and unlock video in motion.
Also, the above technique in the video doesn't seem to work on a S class? That's a CL.
Pre 2008 w221 with rear view camera had active lines, the lines were generated by an additional module situated in the left rear wing made by Japanese company Aisin.
After 2008 they deleted this option and all had static lines coded in to the headunit
I bet even if you somehow rigged up the hideously expensive module (last time I looked it was 1999 US$) you will be stuck with the static lines as well from you comand unit
as for video in motion, I would expect its changeable in the star menu to turn on and off.... not all countries have it as illegal, and if you have split view left hand drive vs right hand drive cars need it swapped side to side anyway
