Garage door homelink, very short range!
Old Mar 17, 2014 | 09:26 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
The range is horrible. I've used homelink in other cars to open my garage door and as soon as I pulled into my driveway it would open. Now, with this car, I have to be in front of it for it to open! I thought something may be wrong, but it just seems to be this way.
Old Mar 17, 2014 | 10:28 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
This is because of the coating used in the glass. I noticed this too. It is, however, normal for this type of glass. The S-Class has a solar reflection additive to reflect heat.
Old Mar 17, 2014 | 10:44 AM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Same coating that reduces effectiveness of Radar Detectors im told.
Hd
Old Mar 17, 2014 | 11:20 AM
Atcpup's Avatar
S550
I have 2 openers and have never noticed a range problem.
Old Mar 17, 2014 | 11:35 AM
Jason B's Avatar
Ok. So my next question is. How well does this coating work? It is all hype, or in the hot summer months, does it really keep the car cool inside?
Old Mar 17, 2014 | 11:36 AM
Jason B's Avatar
I'm taking about when using the "homelink" buttons below the rear view mirror...
Old Mar 17, 2014 | 11:53 AM
ImInPA's Avatar
Yes. I am talking about home link. I get greater range with the native garage remote, but, it is still not that great. It is the infrared reflection coating.
Old Mar 17, 2014 | 12:49 PM
natcahd's Avatar
Veteran: Air Force
Atc....Listen up, the homelink in the mirror. Or do you have two of those?
Hd
Old Mar 17, 2014 | 12:59 PM
natcahd's Avatar
Veteran: Air Force
Old Mar 17, 2014 | 01:10 PM
Atcpup's Avatar
S550
We are talking about the same thing. I have 2 garage door openers and using the "homelink" buttons I do not have a range problem. It might be 2010 "facelift" upgrade for you and HD JK btw....
Old Mar 17, 2014 | 04:32 PM
Jason B's Avatar
Same issue with the 2014+ w222:
https://mbworld.org/forums/new-s-cla...ted-range.html
Now, I'm still curious to know if these coating really helps keep the car cool when sitting in the sun? Or is it more of a gimmick.
Old Mar 18, 2014 | 08:19 PM
RGS's Avatar
RGS
2022 S500 4Matic
Where is the HomeLink Antenna?
All,
I have a 2007 S550 and have the same short range issue. I can "buy" the window coating argument, IF the antenna for HomeLink is in the rearview mirror. Does anyone know for sure?
I actually had to add a remote receiver to the Garage Door Opener and place the antenna at he garage door opening, and even then my MBZ must be pulled right up to the door in order to work. Really short range!
RGS
Old Mar 19, 2014 | 05:43 AM
Donnymac's Avatar
63 Falcon vert
I have noticed the same thing. Based on my garage setup, I think the transmitter is directional as in forward looking only with a narrow beam. As to signal range, i have no clue but there is a directional component.
When in the driveway out side of the garage, I can have my front bumper inches from an adjacent door and the main door will not open. If I backup 3 feet, the main door will then open from the offset position.
My hand held remotes do not have this directional issue. As to signal strength comparing car to handheld who knows. The car has limits the handheld does not.
If glass coatings are the limiting factor, we are driving excellent reflectors for the radar guns.
Old Mar 20, 2014 | 09:39 PM
steveb9771's Avatar
2007 CL550
Originally Posted by RGS
All,
RGS
The antenna is in the mirror. This is obvious based on the programming instructions which require you to place a hand held remote very close to the front of the mirror to get it to learn the code for the device.
Old Mar 20, 2014 | 11:37 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
You may get increased range performance by adding a wire lengthening the antenna wire that hangs off the opener motor..just a thought
Old Jun 3, 2014 | 12:15 AM
AljoGaviola's Avatar
2012 e350 bluetec / 2014 s550
I have my 2014 S-550 for about a month now and my only issue is the homelink very short range. My previous 2012 E-350 had far better range and it's so annoying that you have to push the buttons a few times and be right in front of garage door before it opens. Has anyone found a solution to this problem. Very disappointing that a car loaded with so much technology would screw up on a supposedly very simple homelink feature. Someone ought to bring this up to the engineers at MB.
Old Jun 3, 2014 | 11:01 AM
Jason B's Avatar
Correct. It's due to the various coatings on the windshield. No fix.
Or do what I did, control your garage doors from your phone with x10, from anywhere.
Old Nov 10, 2014 | 12:12 PM
Jason B's Avatar
Fixed this by adding tinfoil on the bottom of the antenna like a little snake...
Old Nov 18, 2014 | 10:19 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
I got tired of getting honked at parking in the street waiting for my gate to respond so I added a Zwave control to my gate and garage. Now I can open it 1/4 mile away from my phone.
U can look at the MyQ.
Old Dec 5, 2014 | 02:10 PM
DaveW68's Avatar
Veteran: Army
2015 S550
I can open and close my garage door from several houses away with my S600. But I have an early production 2007 that has the extra antenna nub on the trunk lid, so that might have something to do with the great range.
My E60 M5 had brutal range with the Homelink system. I basically had to pull right up to my garage to get it to open or close. But BMW's are well known for poor Homelink range.
Old Dec 6, 2014 | 12:42 PM
Nuru's Avatar
S350 BT 4MATIC
Here's a question did anyone try to open a window and see if that improves the range. Since the RF transmission probably has side lobes, you may just simply open up a window and get more RF energy out of the car?
Old Dec 6, 2014 | 10:30 PM
platt-deutsch's Avatar
2019 S450
I have S550 2007 and range is excellent. Factory windshield. My Valentine radar detector has great range also..
