Radiator replacement S550
Old 02-27-2015, 09:07 AM
snovvman's Avatar
I'm your huckleberry
How *is* the quality of the "OEM-Quality" replacement radiator? How is the finish, fit, plastic quality, etc.?
From my experience, parts that claim to be OEM-quality rarely are, especially when they are relatively inexpensive. On the other hand, those that are "OEM brand" are generally okay. 3rd-party manufactures are under contract with the factory to produce parts, they are often allowed to sell the same parts through non-dealer channels, but cannot display the factory logo. Those parts are the exactly the same as factory, just without the factory logo and come with a discount.
I'm just curious about the radiator you got. Thanks.
Old 02-27-2015, 10:09 AM
castroadan's Avatar
09 S550, 08 Charger Srt8, 63 Ford Galaxie 500, 07 GSXR1000
Originally Posted by Nickthegreek
Wow very nice!! Just wondering was the hard part getting the oil cooler and condenser off ? It looks like you just had to unclip them. I'm guessing the crossmember was also challenging because it had many things bolted on it?
The condensor just unclips, the cross member had a big torx bolt on each side and then 2 10mm bolts on each side and it comes off.
Old 02-27-2015, 10:11 AM
castroadan's Avatar
The quality of the radiator looked just as good as the oem. All the bolt holes lined up that support the condensor. The holes for the ac lines connected perfect. The holes for the radiator hoses and retaining clips were perfect also.
So far no leaks.
Old 06-02-2015, 03:07 PM
MBCaulan2015's Avatar
S550 MB
radiator replacement
Bro where you located ? I may need you to replace mine !! Euro fix is charging me 1,400 bucks !!
Old 06-02-2015, 03:59 PM
bha
bha's Avatar
13 GL350, 14 SL550
$1200? Sounds like they are selling you a marked-up part and tacking on a bunch of high priced labor.
The part is $300 on RMEuropean's website.. possibly cheaper elsewhere. And the brand is Nissens which I believe is OEM (Mercedes has only really used Behr and Nissens in recent years).
I'd buy that part and put it in yourself. Maybe do the hoses if you feel like it and they are older.
I haven't done one on this car, but I'd be surprised if it took you more than a few hours to do the entire job. Drain the coolant at the beginning and refill with fresh at the end. That way you have the coolant done also and your cooling system will be in great shape for years!
Old 11-20-2015, 07:49 AM
castroadan's Avatar
Radiator still going strong
Old 05-08-2016, 12:16 PM
  #32
Ozziegarza76's Avatar
2008 w222 s class
Quick question
Did you have to remove the bottom cross bar? I'm stuck on last part. There seems to be a clip or something on the bottom holding the radiator and condenser. Thanks in advance.
Old 11-28-2016, 01:31 PM
  #33
604benz's Avatar
2015 S550V
Hey Castroadan
Hows the radiator, any problems with it, I'm looking for one and found one on ebay for $100
Old 11-28-2016, 01:39 PM
  #34
castroadan's Avatar
Originally Posted by 604benz
Hey Castroadan
Still going strong, no leaks so far.
Where is yours leaking from?
Old 11-28-2016, 01:51 PM
  #35
604benz's Avatar
2015 S550V
Mines leaking from drivers side, where the air intake is attached to the radiator, its got a hairline crack.
Old 11-28-2016, 02:02 PM
  #36
bha
bha's Avatar
13 GL350, 14 SL550
Hey Castroadan
Don't buy that radiator!
There is a cheap Chinese radiator floating around.. sold under various brand names. If what you are buying isn't Behr (or one of the other good brands, can't remember exactly but maybe Valeo?) then it's the cheap one.
I got one and it was total garbage. Got it installed and it leaked. Took it out and found that the plastic tank had a large crack in it. I'm sure lots of radiators get damaged, but the plastic was thinner than the Behr one that I bought afterwards.
Wasted 2-3 weeks and a radiator install to find out it was junk.
If you compare it with a Behr side by side, it looks like it will fit and work perfect. But if you look closely, it's lighter, the plastic parts are thinner, the metal parts look flimsier, and all of the fittings look like they cost 1/2 as much to produce.
That radiator won't last nearly as long as a Behr will. The scary thing with our cars is if the cooling section cracks or fails (plastic tank, etc) you will overheat the engine fast if you're on the highway. If you get a transmission fluid leak, you'll quickly empty the transmission of fluid without even knowing. If you're driving at 60mph on the highway, you'll never even know the transmission fluid leaked out till your transmission wont shift any more.. at that point it is garbage.
Most of the hoses pop on with quick connect fittings, so the tolerances need to be exact. If one hose pops off you're screwed.
Best thing I ever did was to buy the Behr radiator. Yes it's more expensive (a few hundred $ more) but it's WAY worth it.
By the way, I contacted the seller and they completely ignored me and Paypal. Filed a claim with Paypal but it was too late. Ended up boxing it up and putting it at the curb for garbage pickup which sucks... brand new and it was a piece of garbage..
Old 11-28-2016, 02:58 PM
  #37
castroadan's Avatar
Pretty close to where I had my leak.
Old 11-28-2016, 02:59 PM
  #38
castroadan's Avatar
Going on 2 years now and no leak. Still going strong.
Old 11-28-2016, 03:17 PM
  #39
604benz's Avatar
2015 S550V
I ordered one from eBay for $130 Canadian plus shipping, seller had sold over 80 of them with 100% positive rate
I'm going to try to JB Weld mine at the crack as I'm only getting the low coolant message every 2 weeks, if it works that's cool, otherwise ill install the new one.
Is this job a DIY, how many hours labour should it take
Old 11-29-2016, 01:32 PM
  #40
castroadan's Avatar
I did it myself and it took about 3 hours.
Old 11-04-2017, 10:03 PM
  #41
CivilEarth's Avatar
07 S550
Hi I have the 07 S550 with V8 with engine 273 with the same leak - air intake by driver side problem (seems like manufacturer defect that warrants recall); according to the instruction I don't need to discharge the AC since it is engine 273. How to disengage the AC condenser - by pulling it off? Do I need to to recharge the Automatic transmission fluid as indicated in the instruction list? Please help, thanks!
Old 11-18-2017, 07:13 PM
  #42
wilderS65's Avatar
2007 Mercedes S65 AMG
Takes a lot longer on the S65
Old 01-13-2020, 04:03 PM
  #43
lkchris's Avatar
'07 GL320CDI, '10 CL550
Looks like there's quite a few things you have to take off. As far as evacuating the AC I wonder if you can get away with not doing that as long as you're careful with the condenser. When I did my engine mounts I didnt follow the official procedure and got it done much quicker and took very few parts off lol Good luck
Evacuating the AC instruction applies only to M156 engine installation which means AMG S63
Quick Reply: Radiator replacement S550
