is this where my leak could be coming from?
Old Feb 7, 2015 | 10:04 PM
Zerocarpileup's Avatar
2008 S63
So I recently changed out the plugs that are prone to oil leak in the back of the engine. All three and it seems like there is no leak there anymore. But I'm still getting the smell of burnt oil and I still see burn oil on the passenger side catalytic converter. What is this part on the passenger side of the engine that is right next to the plug I replaced. It seems like it might be leaking from here. Is this the pcv unit? The hose ends up going into the the throttle body tube it seems.
Attached Thumbnails is this where my leak could be coming from?-rps20150208_000444.jpg   is this where my leak could be coming from?-rps20150208_000519.jpg
Old Feb 8, 2015 | 12:11 AM
konigstiger's Avatar
'71 Pinto
Second picture here https://mbworld.org/forums/s-class-w...ml#post6242934 is centrifuge (replacement kit http://www.ecstuning.com/Mercedes_Be...961/ES2730580/), third picture expansion plug.
Old Feb 8, 2015 | 01:10 AM
2008 S63
Yes this the part I was referring to. Thank you.
Old Feb 9, 2015 | 10:18 AM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
konigstiger,
Thank you for posting the link to our site!
David
Old Feb 9, 2015 | 08:32 PM
2008 S63
Does the entire system need to be updated or just the oil separator? Has any one else did this maintenance? I am unfamiliar where the other parts are located.
Old Feb 10, 2015 | 10:06 AM
'71 Pinto
As it concerns the leak at the very least you will need to replace housing cover & centrifuge. Here are the individual part #s in the order they are shown in ECS kit link above to comparison shop. Note EPC shows all parts installed at production with the exception of bolts are replaced which may indicate modification.
* centrifuge 2730100162
* housing cover 2720100631
- oil separator 2730160134
- housing cover bolts 000000001478
- centrifuge bolt 000000003495
- bleed hose 2730180582
Replacement of all parts simply requires removing air filter housing, as mentioned here http://workshop-manuals.com/mercedes...ce_and_repair/
