Smartkey & Keyless Go behavior questions
In the 2013 manual, I read that in order for the Keyless Go to work, the Start/Stop Button "must" be inserted.
Does the Start/Stop Button have active/passive circuitry? Or, does it simply extend into the key slot so that you can activate the button inside? It would be great if I can leave the Start/Stop Button out and still use Keyless Go.
Why? Example: On a hot day, I can hand my GF the Smartkey, she gets into the passenger side, and start the car.
I know having a remote starter will make the point moot, but I am just curious what is magical about that button.
Thanks.
Thanks.
Which is why I wanted to know if I can leave out the button and still retain the Keyless Go feature. This way, she can put the key into the slot, turn and start the car from the passenger side. When I'm alone, I can still push to start (albeit without the button).
Without the start/stop button in the ignition slot the only way to start the car is to insert a smart key into the ignition slot.
But when using a smart key to start you do not need to depress the brake, i just tried this to be sure. Hope that helps.
I'm really not trying to
W220- 2000 S320 German Import | W221 2008 S350 German | W205 C250 | W205 C180
My S320 has the button on the gear lever. :-D. so short of a downgrade you are out of luck
