Rear electronic Headrest won't go down fully
Old Feb 21, 2015 | 05:05 PM
Ellton's Avatar
w221
Hi All!
There seems to be a little issue that I cannot find a solution for. Would appreciate any help possible!
An object got in between the electronic rear headrest whilst it was moving down into the "resting" position. So the headrest never quite managed to fully go down.
So now when it moves upright during use it is perfectly fine as always but when it needs to go back down it does never quite reaches the very bottom of the "resting" position.
Would anyone know how to reset this behavior?
Old Feb 21, 2015 | 11:33 PM
konigstiger's Avatar
'71 Pinto
Have someone check for fault codes with MB DAS. You can remove/reinstall headrest in question but not certain if this will resolve matter: http://workshop-manuals.com/mercedes...nt/page_21743/ (+ next page). I assume you are inquiring about 221 since you are posting in this forum.
Old Feb 22, 2015 | 06:47 AM
Ellton's Avatar
w221
Thank you very much konigstiger!
Indeed I am inquiring about the W221 but I initially signed up on the forum so I could fix up an older W220.
Your link really helped!
Looks like the "rear head restrain inclination adjustment motor" has to be "normalized" via STAR.
Either way it makes sense to check that first before starting to take things apart.
Shame that this cannot be done without STAR.
Old Feb 22, 2015 | 09:30 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
This is a rare option? I've never seen any s550 rear headrests go up by themselves. You have to manually move them back into place.
Old Feb 22, 2015 | 10:06 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Incorrect. If you have the rear seat package, the headrests will go up automatically when somebody sits in the back seat.
Old Feb 22, 2015 | 10:27 AM
Ellton's Avatar
w221
It is an S350 but I assume you are right that this option isn't too common as I cannot find a video for it.
The propping up and down of the headrests is all done automatically. Once a person in the rear belts up, the headrest automatically rises. The driver can also make the headrests rise and lower them. The middle one has to be propped up manually.
I hoped that the resetting of this would be as simple as the windows on an W220 : )
Old Feb 22, 2015 | 11:01 AM
Jason B's Avatar
This really should be a standard feature of all S550's. Why the heck is the button up front to make the headrests drop down, but no way to put them back up? This isn't 1970. Sometimes I'll never understand them.
Old Feb 3, 2017 | 06:48 PM
sonnypet96's Avatar
2009 S550 4Matic 2005 SL500
Hi did you ever find a fix, I'm sure a star system wouldn't do anything
Old May 11, 2018 | 03:07 AM
mgokool's Avatar
08 S550 4Matic w/ AMG Pkg & P3
Works
Just noticed this same issue with my right side rear headrest. After running the rear seat normalization function through my scan tool, the head rest retracts all the way down again.
So, YES...STAR or any other diagnostic tool which can perform the normalization function will work.
Old May 11, 2018 | 10:04 AM
lionsfan54's Avatar
Mercedes Benz S600
thanks for this info. My friend has a high end Snap On scanner, so we'll try this!
Old May 13, 2018 | 10:10 AM
becosemsaida's Avatar
E-200 CDI on steroids (W212)
The headrest not coming up in a high end car is really something that i can't understand. It's not so easy to do since we have already "air" in the trunk. Never heard of a back seat package, long version only maybe?? Even though my S-class has less "gadgets" then my OLDER BMW 730D i still prefer MB.
Never had any problems with my 2004 BMW though....... and it just has 450.000Km
My MB is just a child near this one with 230.000Km.
Beco
Old Nov 28, 2018 | 02:56 PM
Kevinlfifer's Avatar
s550, gl450
all 3 of my rear rests won't go down when you push the button, I do here a click but nothing happens
Old Nov 28, 2018 | 02:57 PM
lionsfan54's Avatar
Mercedes Benz S600
Heads up that the center headrest is not powered
Old Nov 29, 2018 | 01:53 AM
lika1's Avatar
S550 4MATIC
Mine wouldn't go down all the way on the rear seat behind the driver's seat for almost a month, then out of nowhere it started functioning correctly.
Jason, W221s with the rear seat package all have the powered headrests. They don't just drop down, they are motorized and slowly go up and down with a push of the same button.
Old Nov 29, 2018 | 10:35 AM
Jason B's Avatar
Yea it’s a shame thought was only 5% of S550’a have that. Should be standard.
Old Mar 20, 2021 | 09:43 AM
JoelS's Avatar
S550 4MATIC
Unhappy
Originally Posted by Ellton
Hi All!
Hi Ellton,
I was wondering if you had found a solution for your car headrest problem. The headrest won't manage to fully go down to the bottom of the "resting" position.
I know that this is an old thread. Would love to know what you did. Regards
Joel
Old Mar 26, 2021 | 10:29 PM
mgokool's Avatar
Originally Posted by JoelS
Hi Ellton,
Joel
See my reply a few messages above...use scan tool to initiate rear seat normalization and it should fix the issue.
Old Mar 26, 2021 | 11:38 PM
JoelS's Avatar
S550 4MATIC
Hi,
I did exactly that and it worked like a champ!!
Thanks a lot!
