airmatic question
Old Mar 3, 2015 | 09:36 AM
rusbel's Avatar
2006 E55 - obsidian black, all options except pano roof - gone but not forgotten
airmatic question
Hi guys,
I have 2010 s550, 40 k miles. The compressor seems noisy when starting cold, then goes away after 45 seconds or so. Also happens when raising the car level manually ( by pushing the button ). The suscpension seems to work fine, the car raises and lowers as it should. Is this an expected noise or does it mean that the compressor is about to fail?
Thanks!
Old Mar 3, 2015 | 11:33 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Our online tech Mike will reply shortly...
Old Mar 3, 2015 | 11:35 AM
SwineHund550's Avatar
2010 S550 4Matic
Mine has a whine noise at start up. If I move the steering wheel back and forth It changes pitch. yours?
Old Mar 3, 2015 | 12:42 PM
rusbel's Avatar
I haven't tried the steering ..will let u know..
Old Mar 4, 2015 | 12:14 AM
rusbel's Avatar
No, the steering wheel def has nothing to do with it
Old Mar 4, 2015 | 01:32 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
At first glance thought this said "MIKE has a whine noise at start up"...LMAO
Hd
Old Mar 4, 2015 | 02:20 PM
Mike5215's Avatar
2016 C300
Shouldn't be any audible sound in the cabin from the compressor. It's an S Class for cryin' out loud! It may be an early sign of trouble. As long as you're not getting warnings and the car raises and lowers normally I guess it depends on how noisy it is and whether or not you can live with it. Is there a warranty?
Old Mar 5, 2015 | 12:31 AM
rusbel's Avatar
Nope, factory warranty ran out in September September.
Yeah, no warnings or any probs just yet...
Old Mar 5, 2015 | 09:33 AM
castroadan's Avatar
09 S550, 08 Charger Srt8, 63 Ford Galaxie 500, 07 GSXR1000
Turn your wheel to the right and pull the plastic liner back. Hit the raise button and look into it. Maybe one of the 3 bolts and springs that support is is missing or not secure.
Old Mar 5, 2015 | 11:31 AM
rusbel's Avatar
Will try that, thanks!
Old Mar 9, 2015 | 12:19 AM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
https://mbworld.org/forums/s-class-w...-pump-diy.html
If you end up deciding to replace it, its a not so bad DIY. Only warning is if you live where they use alot of road salt buy a new bracket because the nuts holding the pump on the bracket tend to shear off
Old Mar 9, 2015 | 08:53 PM
Nuru's Avatar
S350 BT 4MATIC
Try to remove using PB blaster first though.
