P0607 Voltage supply of component Motor electronics / Battery voltage too low ADC
Old Mar 5, 2015 | 11:19 PM
stkrtr's Avatar
2007 Mercedes S550
Has any one encountered this issue with Mercedes S550.
My car dies down on the road and then won't start for sometime, even for days and at other times will start right away. Had a mechanic run diagnostics and this error was found
P0607 Voltage supply of component Motor electronics / Battery voltage too low for ADC
Any suggestions will be very helpful.
Thanks.
Old Mar 6, 2015 | 08:10 AM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
Either the ECM is failing and needs to be replaced or check your battery/alternator
Old Mar 6, 2015 | 10:21 AM
stkrtr's Avatar
2007 Mercedes S550
If the car dies while running. Could it still be battery or alternator? Although the battery is seven years old,the local AutoZone checked it out to be fine. Also when the car goes in no start state and the engine doesn't turn, the battery seems to work fine for extended period of trying to start it.
Old Mar 6, 2015 | 12:47 PM
Maybe theres a bad connection somewhere. If not sounds a failing ECM
Old Mar 6, 2015 | 02:00 PM
alx's Avatar
alx
the code might be a side effect to a bad crank position sensor.
i would troubleshoot as follows:
1. check battery terminals (corrosion, tightness)
2. replace cps (cheap)
3. replace battery (more expensive, but at 7 years you are long overdue)
4. replace engine mgmt module ($$$$ and requires scn coding)
Old Aug 27, 2018 | 04:20 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Who replaced the compressor?
Was the A/C system properly recharged and who recharged it?
Clear the codes again and post all the codes that will not delete.
Old Mar 13, 2022 | 08:01 AM
06SL500AMG's Avatar
2006 SL500
What was the outcome of the fix? I have code P0607 along with a lot of 02 sensor codes and a 1337 code. I know it's an old thread but I'm hoping there was a solution.
Old Jan 11, 2026 | 11:33 AM
moe_s's Avatar
hey could you fix the issue? I have similar problems with lots of o2 fault codes
