Official S63/S65 face lift thread
Old May 7, 2015 | 09:21 PM
Zerocarpileup's Avatar
2008 S63
Ok so I've searched high and wide through the site with no actual play by play on how to face lift a base 2007. I've seen numerous pictures and post but still confused about all I will need.
Hopefully this thread will continue on to all its glory as members can chime in.
My concerns are:
1. Type of body kit and where to purchase. I understand that fiberglass is a no no.
2. I was told I will need some structural peices for the body kit wicch include impact bar and some others.
3. Headlights. I've noticed some use oem and need a which doctor to make them work. Others buy reproduction and complain of the quality.
I'm sure I'm missing tons of things that should concern me. Can we pack as much info in one thread so one could get all the information needed to turn out an awesome facelift!
Old May 7, 2015 | 09:47 PM
S500 Man's Avatar
White S63 AMG W/Designo Interior
Contact Gary for facelift kit...
Old May 7, 2015 | 09:57 PM
2008 S63
Yo what's up man! Congrats on the new whip. That thing is mean. But who is gary?
Old May 8, 2015 | 04:32 AM
wywywywy's Avatar
W221 S500 SWB
There's only one (far eastern) manufacturer for the facelift kit as far as I know. And it's made in polyurethane. It has both simplified and traditional Chinese so I don't know if they're from China or Taiwan, but it's most likely a Taiwanese company with a factory in China, like many of the polyurethane body kits.
There are many manufacturers for the pre-facelift S63/S65 kit, and it's in fibreglass.
Not "structural" more like big brackets, and they're in the boxes already but you will need to reuse some bits from your current bumpers.
I don't have them but I don't think the reputation of the aftermarket part is too bad?
Old May 17, 2015 | 06:51 PM
2008 S63
Say I'm going to do the quad tips to stock mufflers. Which type of tips am I supposed to use. I see one that has the joint in the center and the other are joint off to the side.
Official S63/S65 face lift thread-screenshot_2015-05-16-16-40-07-1_1.png
Official S63/S65 face lift thread-screenshot_2015-05-17-17-44-22-1.png
Old May 19, 2015 | 05:41 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
I Think you find most info you need in my W221 S500 facelift thread.
1. Yes...fiberglass is a no no. And the new kit is also made in fiberglass by some makers. As said, Contact Gary if you are located in the US.
2 Depends a bit on what kit you have now but yes. All parts for 100% fit is not incuded in the kits.
3. If you buy the corect cablekit for OEMs you have no problem att all with the install. Am about to try the aftermarket lights for nightvision my self now so I let you know how it goes.
When it comes to the pipes it also depends a bit on wich Engine and wich kit you have now. Best way to know is to install the new rear bumper and see wich one that fits your car.
And when it comes to the mirrors they are mostly plug n play. Depends a bit on Euro or US version though as it seems. o buy US version if you are in the US. And of course with the right features.
Old May 20, 2015 | 03:27 PM
2008 S63
Thank you. I'm going to revisit your thread. Do I need to have the lights programed by STAR? Also were the led fogs plug and play into existing fog light harness or did we need some type of resistor?
Old May 20, 2015 | 03:43 PM
aznevoviii's Avatar
G63 AMG
any muffler shop can work with any of those pipes.
but i got center inlet one from gary, it fits perfect in there.
Old May 21, 2015 | 10:50 AM
Depends. OEMs need programming. Instructions is inluded on how. With the Cable kit for OEMs it is plug n play. Aftermarket it needs resistors.
Old Jul 14, 2015 | 05:42 PM
2008 S63
Ok so the kit is on. But I need some advice from you guys. I having a couple of issues.
1. The front bumper has a gap between the front bumper and grill. Total eye sore.
2. The LEDs don't work at all. One flickers the other won't turn on at all.
The LEDs are more worrisome. I got the kit from Gary. The guys doing the install in pretty well known in Chicago for dealing with high end cars. They are familiar with the facelift procedure as they have done a few. They tell me they tried connecting the LEDs to every and nothing works. They even tried to run straight from the battery and nothing.
has any one run in to this issue and resolved it? Bad LEDs?
I have a 2007 base. The fog lights worked fine before the facelift. (That it where they initially tried wiring them to as I preferred to use them as fogs and not drls).
How about the body kit gap. The sides of the grill and the lower center part of the grill look bad.
Old Jul 14, 2015 | 05:44 PM
2008 S63
Old Jul 14, 2015 | 06:38 PM
wywywywy's Avatar
W221 S500 SWB
The gap doesn't look too bad from the picture but it's hard to tell on a black car from a picture.
One side of my LEDs was dead on arrival like you described. I cut it open due to curiousity, and it's to do with a very very poor solder joint inside. I didn't get it from Gary but it's the same Chinese/Taiwanese manufacturer. I had to get a replacement.
EDIT - Even genuine S65 has a gap too. If I remember correctly it's about 1cm.
Old Jul 14, 2015 | 06:56 PM
DaveW68's Avatar
Veteran: Army
2015 S550
What shop did your install? And what did it cost for paint and install?
Old Jul 15, 2015 | 03:14 AM
Sick07S600's Avatar
S600
Please keep this topic going !!
Old Jul 15, 2015 | 03:41 PM
MonroeHandyMan's Avatar
2007 S550 4Matic 2009 ML350 4Matic
Watching this post. Any more pics?
Old Jul 15, 2015 | 09:26 PM
S500 Man's Avatar
I bough
I bought this for my facelift drl runs great plugged straight to battery auto on and off
Old Jul 16, 2015 | 03:19 AM
Here is mine:
Not changed the grill yet though..
Old Jul 16, 2015 | 06:24 AM
S500 Man's Avatar
Are those oe headlamps or the AM?
Old Jul 16, 2015 | 12:22 PM
OEM
Old Jul 17, 2015 | 05:53 AM
2008 S63
I went to Chicago autohaus on Elston and wolcott. They painted and installed front & bumper, side rockers, grill, side mirrors and a spoiler for about $1700. Some of the cost was for the additional parts that were needed for the retrofit. They took care of some dents scratches and dings for a little bit more. Overall I am very please and impressed with the work. I would definitely recommend them to anyone that wants the facelift done correctly. I believe the owner is named Saif and dealt with him directly. He is very informative and familiar with the procedure. While there, I noticed some high end cars getting some TLC also.
Old Jul 17, 2015 | 05:57 AM
2008 S63
Does any know the proper wattage and ohms needed for the resistors say I want to wire them to the fog light switch. I see so many combinations on the web.
Old Jul 20, 2015 | 04:34 AM
Wonders's Avatar
W221 S600
Are there any drl's that will fit S600 with sports kit body, car has round fogs but i want straight drl's, can't find anyone who sells them.
Old Jul 20, 2015 | 04:39 AM
Simply NO! You must have facelift bumper.
Old Jul 20, 2015 | 05:22 AM
Wonders's Avatar
W221 S600
Thanks Chris, my bumper does not have holes for parking sensors, it uses radar, is that a problem with facelift bumper.
Old Jul 20, 2015 | 05:26 AM
Yes. See my build or facebook page. You need a version without holes then.
