Tire size 4 matic to staggered.
As the suspension travels up or down the bar travels with it and pushes down or pulls up a lever on the sensor, varying its output voltage (kind of like a dimmer switch on a lamp).
Because the bar is a fixed length, the Airmatic/ABC controller knows where the car is sitting height-wise based on the voltage output of the sensor, and then it makes its adjustments as needed to keep the car at the "right" height.
If you replace that fixed-length metal bar with a bar with an adjustable length, you can cause the sensor to send information to the controller that the car is sitting higher than it actually is, which causes the controller to respond by lowering the car.
The "links" are not load bearing and not a part of the working suspension. They could be made of plastic and still work as intended.
. In my defense this has been the longest ive owned a car and not changed the wheels!!! could also be ive been renovating my house and most of my funds are going to that!!
2 options:
255/35/20 front and rear
or
255/35/20 F, 275/35/20 R
