ABC Flush Tool
Old Mar 20, 2016 | 01:50 PM
Wonders's Avatar
W221 S600
ABC Flush Tool
AGA Mercedes Benz ABC Flush Tool
Hi guys, has anyone on here used this tool, want to flush my ABC but mercedes tell me there is no scheduled service for my system, does an 07 S600 have an ABC filter like shown.
Old Mar 20, 2016 | 11:03 PM
Mike5215's Avatar
2016 C300
The ultimate ABC flush tool:
Old Mar 21, 2016 | 07:59 AM
Wonders's Avatar
W221 S600
Stupid!
Old Mar 21, 2016 | 08:33 AM
Mike5215's Avatar
2016 C300
Well yeah, you'd still need to fill in the make and model part with a Sharpie. Otherwise the sign makes no sense.
Old Mar 21, 2016 | 09:40 AM
alx's Avatar
alx
You don't need a tool. Unhook the reservoir return hose and put it into a bucket. Top off reservoir and start rodeo. Top off reservoir as needed. Make sure you really keep at it as if you run empty you can damage tandem pump. Run until clear fluid comes out of return hose. About 8-10 quarts of Pentosin.
Edit- or follow Mike's advice. 100% results guaranteed
Old Mar 21, 2016 | 11:00 AM
Wonders's Avatar
W221 S600
Thanks, does an 07 S600 have an ABC filter and does this process flush power steering as well.
Old Mar 21, 2016 | 11:05 AM
bha's Avatar
bha
13 GL350, 14 SL550
I did it the way ALX mentioned. Very easy.
Keep the fluid full and don't let it run dry. If you uncap all of the bottles and have them ready, you can do it with one person. You need to pour relatively quickly, but you can definitely do it by yourself if you are prepared.
I went to home depot and got a 5gal bucket + a lid. Plus a 10ft of clear vinyl tubing.
Put the vinyl tubing on the return line and wire tie it tightly so it doesn't come off. Drop the other end in the HD bucket and do the flush.
Then put the lid on the HD bucket and drop the fluid off wherever they accept motor oil for recycling.
Old Mar 21, 2016 | 11:31 AM
Wonders's Avatar
W221 S600
Thanks bha,
was there a filter and did steering fluid get flushed at same time
Old Mar 21, 2016 | 11:38 AM
bha's Avatar
bha
13 GL350, 14 SL550
Yes, there is a filter. When you pop off the ABC reservoir lid, the filter is attached to the underside of it. You will see what I mean when you pop the lid off.
Pull hard on the filter and it comes off. Then push the new one on and you're done.
I flushed the system with the existing filter because I didn't want to contaminate the new filter with old fluid.
Get the latest part # for the filter, because a few years ago (5-7 years?) they updated the filter and it has smaller holes to trap more gunk. The new part # is much better. Most places probably don't have the old filter any more, but be careful if you buy from eBay or places like that. Any dealer or online parts store (ECS Tuning, FCP Euro, AutohausAZ) will for sure only have the new filter.
Steering uses the same pump, but it has a separate reservoir. You'll have to flush that separately.
One way to do it (that I use) is whenever I'm under the hood I suck out the reservoir of fluid and pour in new fluid. If you do it 2x/yr when you do oil changes, you end up replacing the fluid completely every 12-18 months which is perfectly fine. You can of course go through more work to do it the "right" way which is to disconnect the return line and flush. I find it much easier to just swap fluid every time and having year-old PS fluid is fine with me as nobody flushes it every year anyhow.
Old Mar 21, 2016 | 11:48 AM
Wonders's Avatar
W221 S600
that's great, thanks.
wonder why Mercedes say theres no service for ABC fluid when there clearly is, my steering fluid has gone brown, not green like suspension fluid so want to flush complete system, no problems with it but steering fluid shouldn't be brown should it.
Old Mar 21, 2016 | 12:09 PM
alx's Avatar
alx
Abc needs to be flushed every 35-50k miles. Contrary to what mb states it is not filled for life and if you don't flush it on a regular basis the valve blocks will gunk up and the tandem pump will quit.
Old Mar 21, 2016 | 01:57 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
Gents,
The filter is located here if it helps:
https://www.fcpeuro.com/products/mer...ter-0031846101
--Kyle
Old Mar 22, 2016 | 10:31 AM
mercedesbenzs55's Avatar
Acura TL 2008 - Acura MDX 2012
Lightbulb
lol! He's saying that cause he's upgrading to a C-class with airmatic.
Old Mar 22, 2016 | 12:22 PM
Mike5215's Avatar
2016 C300
You should get one of those ABC flush tools. Your car doesn't need it, but when has that ever stopped you?
Old Mar 22, 2016 | 01:36 PM
I'm still working on the muffler bearings.
Old Apr 1, 2026 | 09:19 PM
Srslol's Avatar
W211 W216 W212
Talking W221/C216
Visual representation how I done it.
Thanks to alx saved me from purchasing a tool
Simply lift power steering reservoir and remove the bracket held with 2x 10mm nut
and the ABC reservoir bracket 1x 10mm nut
12v oil pump was used for filling and suction fluid
Blanked off the return reservoir
It is a bit messy though.
Old Apr 1, 2026 | 11:05 PM
JohnLane's Avatar
222 S-65
Your 221 car has bleeders at each corner of the car. Set car to ‘Tip toes.’ With the car on a roll on roll off hoist so you can safely get access to each of them... Open the bleeder and let it drain via a hose to a container. The car will drop at each corner. Don’t earn a Darwin Award not paying attention. Start car to level up, refill fluid and repeat until fresh fluid comes out each corner. This happens after sucking old fluid out of the reservoir and fitting a fresh filter.
I do ABC oil annually. I put 20,000 a year on my car.
Old Apr 2, 2026 | 04:55 AM
BOTUS's Avatar
S500
the cheap real tool - flushes it all at pressure whilst operating the struts so all the crap is agitated so it comes out to save wearing strut seals in 20 mins with almost no tools
you certainly never waste your time with a ramp, or unbolting wheels - why do it any other way ?
