Sound upgrade options
Hey guys, what are my options for upgrading this less than stellar H&K audio system in my car?
Is it possible to just replace the H&K speakers with better speakers, or will the entire system (amps, processor, etc) have to be replaced?
I'm not so much looking for more boom boom, just better quality sound. Any suggestions on nice sounding speakers?
Location: Land of Political Criminals and Urban Shootings
2015 S550
Manofsteelpt (05-06-2016)
Thanks Dave and Mike...
Wow, great read, thx, Mike... So, in a nutshell, I can just replace the 4 door speakers and have better sound? I don't think I would go as far as the dynamat and processor.
Would you recommend the Focal speakers for all four doors? Again, I just want quality sound. Thanks.
I'd do the opposite. The processor can compensate for any issues with the speakers, but new speakers can't compensate for the factory EQ. I was disappointed when I swapped in the FOCALS and Hertz. Barely moved the needle.
To see how fixing the EQ solves most of the problems, scroll to the bottom of the blog and have a look at the $50 Glovebox EQ Mod. That set up is dirt cheap and will give you an idea of what's possible with the Prima. (Requires a 2010+ car or a 2007-09 with the IPod kit)
Yeah, speakers alone make very little impact. You don't have to use an IPod with the EQ mod. Anything you put thru the aux in jack works. Might want to grab a cheap IPod or something on EBay if you don't have a portable audio player.
2015 S550
Attachment 330371
Attachment 330370
Attachment 330369
Heavy duty install but so worth it. It was the shops first Prima in a 221. Took them over 20 hours but they billed six. (I gave the installer a hundred dollar tip.)
All that gear just went into my new C Class.
Attachment 330370
Attachment 330369
Originally Posted by Mike5215
Attachment 330371
Attachment 330370
Attachment 330369
Attachment 330370
Attachment 330369
Originally Posted by DaveW68
Nice clean install in your previous S. The Prima would have to be mounted in a different spot in the pre face-lift models since the spot where you mounted it is occupied by the accessory battery.
Just read Mikes w205 upgrade, nuts how intricate it gets! tbh, I was thinking/hoping it would've just been an easy fix like replace the door speakers. Looks like that would've been a waste of $$$. Glad there are knowledgable ppl on this board!
Thanks again.
Thanks again.
Ha! I tend to get a little long winded. All you really need to know is:
Prima
Small sub amp
Download my W221 Prima tuning file
Done
If you're not replacing speakers, no need to crack open any doors. Everything gets connected back in the trunk.
Prima
Small sub amp
Done
