Engine won't start - ESP/Run Flat
Old Aug 10, 2016 | 04:25 PM
dwfin's Avatar
2011 S350
Hi All,
I need some major help having spent £5,000 with official dealership trying to fix the problem. I get two errors which wont let me start the car until I try a good three times (sometimes just doesn't start at all). Run flat indicator inoperative and ESP inoperative see owners manual. Most recently, the garage have replaced:
- the control unit (trp)
-charge air duct & temp sensor
-mixing chamber
-TRP control
That all came to £4.4k only to have the engine not start one day after. Clearly its not fixed. Any ideas what I can do/what it might be?
Thanks so much!
Old Aug 10, 2016 | 06:23 PM
alx's Avatar
alx
None of those errors should prevent you from starting the car. You have a different problem.
Does it crank but no start? Or no crank at all?
Old Aug 10, 2016 | 06:44 PM
dwfin's Avatar
2011 S350
No crank at all. Lights, electrics all work fine. If I do a hard battery reset that generally wipes the error and engine starts. It happens every time I drive, turn engine of for a few mins and then try start it up.
They said oil was leaking on the ecu or something like that so replaced everything around it.
Old Aug 12, 2016 | 10:50 AM
bmwcrocop's Avatar
2007 s550
Try replacing fuel pump module in rear trunk and crank shaft sensor and starter battery.
Easy items that may have been overlooked.
If you spent 4K; what's another couple hundos.
Old Aug 12, 2016 | 11:59 AM
alx's Avatar
alx
I assume the car was read with star. What are the errors?
Old Aug 12, 2016 | 03:06 PM
bmwcrocop's Avatar
2007 s550
My starting issues didn't show up in STAR at all.
Old Nov 22, 2016 | 06:16 PM
Dutton88's Avatar
C220
Hi, i am having a very similar problem at the moment, do you have any further updates?
Old Sep 16, 2017 | 06:17 AM
Goldbird's Avatar
Prepower fuse box
Maybe it is the 'Pre-Power Fuse Box' (PN 2045403550) . It produces various different symptoms ,quite similar to the ones mentioned.
Check: https://mbworld.org/forums/c-class-w...t-start-8.html
Old Oct 9, 2017 | 04:42 PM
Davie.b's Avatar
C350 cdi
Having the same issues with a 2010 c350 cdi , can anyone shed some light on the above subject . I had this problem about 6 weeks ago , wondered if Ithadn't gone into park properly and didn't really think much more about it until it happened today again and then about 3 hours later , I'm currently getting away with getting out the car and locking it , then all seems ok and fires up first time , noticed the glow plug light isn't lighting up when it's playing up . Any help /advice would be much appreciated
Old Nov 8, 2020 | 03:52 PM
Shahaid's Avatar
S350 2010
Hi All,
-mixing chamber
-TRP control
Thanks so much!
hi I see thus post is from few years ago but I have the exact same issues. Did you manage to diagnose the problem?
Would be great if you could share it
Old Aug 31, 2021 | 01:51 PM
Ahmedkhokar's Avatar
s350 2011
any update to resolve this issue
hi
did any of you found any solution ? . i am having same issue once a week i just remove battery it clears code and works fine for 1week or more.
Is deactivating Attention asist would work to bypass (hard battery reset?).
Many thread reflect Brake light/ speed sensors. My run flat indicator restart option grey out when this issue happens. I read one place E-class to overcome issue disable attention assist. will this also work for S-350 2011.
Old Dec 6, 2024 | 12:10 PM
gmanmiki's Avatar
Same problem any fixing
Not starting engine in the morning
Car doesn't start occasionally. Run flat + ESP inoperative I had to remove battery and rest
