Spark Plug Module
Old Mar 31, 2017 | 01:59 PM
Canadatru's Avatar
S6000 2006
Spark Plug Module
Hi, would oil spill on the passenger side spark plug module ruin it and the electronics within it, in a 2006 S6000?
Thanks.
Old Apr 1, 2017 | 11:32 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W221 forum...
Old Apr 1, 2017 | 11:59 AM
alx's Avatar
alx
Thanks.
depending if oil got inside. generally speaking - unlikely. but they do go bad for no reason, let alone if you spill oil on them...
btw, usually diagnosing the coil controller is not easy as there are no error codes that point to it consistently. the only codes you will see are misfire codes and some ionic voltage inconsistencies but those can be plugs, coils or controller and are replaced in that order until problem is fixed.
Old Apr 1, 2017 | 07:34 PM
Welwynnick's Avatar
2006 S600
The coil packs are quite well sealed, and in any case oil isn't bad for electronics.......
https://www.pugetsystems.com/submerged.php
Old Apr 2, 2017 | 10:09 AM
GPrime2's Avatar
2007 Mercedes S600
The guy who rebuilt my voltage transformer said they often fail due to moisture getting inside, but not coil packs. I assume you're talking about coil packs not the transformer, so like the other said, unlikely that it got damaged from the oil.
Old Apr 2, 2017 | 10:20 AM
Welwynnick's Avatar
2006 S600
Was that V12IC Pack? They seem to be good.
Moisture means water, and that's always bad for electronics. Oil less so, witness the link.
Nick
Old Apr 2, 2017 | 10:46 AM
alx's Avatar
alx
Oil/ water/ whatever fluid tends to ground things. It is not the getting inside part but the grounding the coil pack at the wrong places to the motor. Add a few thousand volts capable of jumping short air gaps and you find electricity where there should be none ....
