ECU tuning issue
Old Apr 10, 2017 | 11:05 AM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
ECU tuning issue
As per my other thread, I am currently trying to pull the map down from the car and my chosen tuner is having issues with this.
They say they are unable to read the map via OBD or via K - Line and that my car has an odd ECU that requires the eeprom to be removed from the ecu, written to, then soldered back on. Its a BOSCH ME 2.7.2 - A2751500879
I have heard of many 221's/220 65's being tuned, and have not heard of this being an issue.
Can anybody help?
Old Apr 10, 2017 | 11:52 AM
Was looking for recommendations for capable tuners rather than instructions on how to read the ECU myself, but thanks.
DaveW68's Avatar
Veteran: Army
2015 S550
Can anybody help?
The W221 cannot be tuned via OBD port. The ECU must come out and it needs to be bench tuned. You may want to contact Eurocharged as their tunes are well known and are supposed to give great gains without trashing your motor or turbos.
Old Jun 30, 2017 | 02:34 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
The ME 2.7.2 in the M275 S600/S65 is locked down tight and most devices cannot do anything with them. A seed key is required to unlock it, and only Xentry can flash it with official Mercedes-Benz flash files for maintenance reasons. This ECU must be read on the bench, and contains two 512k chips, which contain identical data. The chips can be desoldered and read with the appropriate hardware, or read using an ECU programmer/reader that supports this ME. The KESS V2 OBD2 programmer, however can WRITE to an ME 2.7.2 over OBD2, but not read. The problem is that most tuners require the original data to be read first to ensure compatibility of their tune before it is written. Once read, you should be able to apply as many tunes as you like using KESS V2, and perhaps some other OBD2 programmers.
Old Jun 30, 2017 | 05:32 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
What he said!
They just tuned my 2012 S550 and everything works great!
https://mbworld.org/forums/s-class-w221/659340-just-got-eurocharged-m278-tune.html
Old Jun 30, 2017 | 05:34 PM
In the end, I had the ecu socketed and flashed by a company in the UK. I would rather not use EC as I have had bad experiences with them in the past.
Old Jul 1, 2017 | 03:13 PM
Polar Bear's Avatar
What bad experiences have you had? Jake is on here and I am sure would want to do whatever possible to make it right. PM me if you prefer not to post publicly.
