Coolant leak
Old Apr 27, 2017 | 02:48 PM
Bjjcodi's Avatar
2008 s550 Mercedes benz
Coolant leak
I have a 2008 s550 and have notice coolant in the air inlet duct on the drivers side
Old Apr 28, 2017 | 01:00 PM
604benz's Avatar
2015 S550V
I had same issue, there was a hairline crack in the radiator where the air vent attaches.
I bought a new radiator off ebay for around $150.00 and 2 hour install from indy tech
Old Apr 30, 2017 | 08:49 PM
604benz's Avatar
2015 S550V
This is where my coolant leak was at air intake of radiator
Old May 1, 2017 | 11:41 AM
alx's Avatar
alx
thoroughly dry the area when engine is cold.
let the car reach operating temp and let it run for a few minutes more to make sure thermostat is fully open.
observe area of leakage. you should be able to see where it leaks from. for your setup radiator cracks are common in this area
Old Jan 26, 2022 | 04:19 PM
Jwanko77's Avatar
2007 mercedes benz s550
Is there a fix for this issue
I have the same problem on a 2007 S550 can someone tell me a way to fix without replacing radiator
Old Jan 27, 2022 | 08:06 AM
mcb66's Avatar
clk320
Yep been there done that.
While I was there I also replaced the alternator. Charging was a little flakey and it was so easy to get to with the radiator out of the way. 2 birds with one stone...
