2007 S550 Central gateway N93 failure (Defect)
Mercedes w221 S500
2007 S500 Central gateway N93 failure (Defect)
Hello..Sorry for title my car is S500 german edition i have problem with my passenger windows and rear left & right windows not working i make diagnostic
and look for fault.. The diagnostic show all windows working but i have defect central gateway.. what is the problem and my window stop working? sorry for my English
Location: Land of Political Criminals and Urban Shootings
2015 S550
My driver's window had stopped working and I took it to my local dealer last week. They did a full diagnosis and ruled out a bad switch or window motor. They ended up installing a software update to the window control module which fixed it.
Since you have multiple windows that are not working, my guess is that it's an issue with the window control module. It could be bad or just need a software update. Since you seem to be unable to diagnose the issue yourself, then you may want to let your local dealer check it out.
Mercedes w221 S500
Yes but my dealer make full diagnostic and 4 module from windows show no problem the only problem is this center gateway defect.. is possible my windows not working from this center gateway? how i can fix this gateway buy it new or i can make update on this gateway module?
2015 S550
This is more proof positive that a warranty is an absolute must on these cars.
The gateway is a separate part. But you cannot just swap it- it requires coding - something that can be done at a dealer or offline by somebody who judging by the questions you are asking you are not (nothing personal).
Generally when dealing with electronics you should go to the dealer as there are many and expensive mistakes that can be made while servicing it.
The first thing that I would recommend is have a dealer or independent shop perform SCN coding on this module. This will download the current software from Daimler and flash it to your current CGW, ensuring the software has not been corrupted or tampered with. It will also program the CGW afterwards with the options your car has, and program it the way it was intended when it left the factory. If it accepts flashing and coding, run the Quick Test again to see if the error still appears. This could likely remove the error in the CGW. Then test the windows and see if anything changed there. If they are still inoperative, then start checking the door/window modules and also ensuring they all have the current software.
You will need to have a dealer perform these steps as they will need to login to Daimler AG's servers to obtain the flash data and SA data for your VIN and program it to your CGW module. If you do not have a login and password to Daimler AG, you cannot obtain this information/data.
Rahj kasolo (03-19-2022)
Firmware on newer models is now digitally signed, so it can't be altered nearly as easily.
Amer119 (01-04-2023)
2006 s350L w221
Hi guys.
I would like to ask does anyone know the location of the Central gateway module for 2006 s350L w221. Please advice. Thank you.
And does anyone had encounter the problem for w221 which is the front parking sensor is not working but the rear parking sensor is working fine. And night vision is unavailable to use but I run through test it is working fine. Please. Thanks
Received 4,421 Likes
'71 Pinto
'71 Pinto
Best to have someone pull fault codes using MB diagnostics.
Verado Ting (04-26-2020)
