Lumbar losing air, controller turning off, '09 S550
Things I've done and observed:
First, I researched this forum and found a little discussion which was helpful. Next, I swapped the driver's and passenger's control modules which didn't change anything.
If i give a low lumbar number setting, such 4 or less, the pressure will lose itself more often than if I have a lumbar setting of six or more. This makes me think it is a valve issue with a higher pressure holding valve closed??
Where is the air comporessor for the seat? I have the back off, but can't find it.
I see three lumbar rectangular/flat devices on the right hand side of the lumbar area, each with wires going to them - are these the only valves for lumbar?
Is there a valve somewhere else between compressor and lumbar rectangular devices?
On mbonline, I see there is a part number 221-800-01-78 called valve for $140.25?
Thoughts?
If found to be bladder replacement part is 2219102275 (505 in diagram) pictured here: https://www.ecstuning.com/b-genuine-...er/2219102275/ 2218000178 (530) is not applicable to your VIN see attachments.
Possible DIY bladder repair: https://mbworld.org/forums/s-class-w...-puncture.html
Pump: http://workshop-manuals.com/mercedes...on/page_19152/ see attachment for panel removal.
My car has about 70,000 miles and everything looked tip top behind the seat cover. No kinks, no loose connections.
So there's only one pump, and it's in the trunk.
Does the part number below, the dynamic seat air bladder assembly,
2219102275
have valves which is what is electrically connected on the assembly?
Are these the ONLY valves controlling lumbar, therefore I should order a new bladder assembly? When lumbar fails, the other bladders can still be adjusted.
Many thanks!
next, can I purchase a DTC code reader that is very thorough for my car?
Many thanks again to all!
Im very impressed with the Mercedes quality of workmanship. Every part in the seat has a p/n label and everything is designed to be taken apart or removed. Very nice!
It did take a few hours work, but I was exploring carefully and gently as I realized what had to be removed to get to the air bladder system.
im trying to do the same.... my left bladder making that hissing air sound when compressor pumps air to it...
not a complicated job ?
Seat out is easiest so you can work all around it.
im in Dallas, you?
my old unit has good bags if you want to purchase my old unit. My guess is one of the lumbar controllers failed, but my bladders are good.
pm me if interested
