Bad instrument cluster?
Old Jul 26, 2017 | 07:59 AM
dannyfiveforty's Avatar
2008 CL63 AMG
hi,
my w221 has the wrong needle rest positions, rpm and fuel gauge both sit above zero (see pic attached).
has anyone had this before? What is wrong? I have removed fuse 25 to try to fix but it didn't work (although ignition was off) when I tried, can I try again with ignition on?
many thanks
Old Jul 26, 2017 | 08:17 AM
Mike5215's Avatar
2016 C300
Does it ever flicker or sporadically dim?
Old Jul 26, 2017 | 08:28 AM
2008 CL63 AMG
No, not that iv ever seen anyway..
Old Jul 26, 2017 | 12:44 PM
alx's Avatar
alx
Are the readings offset also when running?
Old Jul 26, 2017 | 01:34 PM
2008 CL63 AMG
Fuel gauge seems a bit up and down and not very accurate, rpm sits high at idle, but will change gear at the correct rpm at redline..
Old Jul 26, 2017 | 08:03 PM
alx's Avatar
alx
Ic can be reset with star/ das, but if that doesn't fix it I say leave it alone. There is no field calibration of the ic... that I know of
Old Jul 27, 2017 | 04:24 AM
2008 CL63 AMG
Ok thanks,
Old Jul 27, 2017 | 04:29 AM
2008 CL63 AMG
Would the needle rest positions be coming from the ecu or the cluster, or, would a new cluster fix the problem or would the ecu tell the needles to sit at the same position??
Old Jul 27, 2017 | 02:47 PM
alx's Avatar
alx
i do not know for certain. i do think that the cluster is responsible for positioning of needles when there are zero readings from the various computers reporting to it.
Old Jul 27, 2017 | 04:13 PM
konigstiger's Avatar
'71 Pinto
As alx suggested, before replacement have someone normalize IC with MB DAS (diagnostics) in addition, check for fault codes and software updates. Need VIN to supply IC part # if steadfast on replacing.
