W221 a great S class series?
Old 08-07-2017, 02:51 PM
DaveW68's Avatar
Location: Land of Political Criminals and Urban Shootings
2015 S550
Originally Posted by alexanderfoti
Yes the 221 is quite a bit heavier as a result. Plastic front wings, ali boot and doors but steel rear section.
mine is 2280kg wet!
The only plastic items on the W221 body are the front and rear bumpers. The front fenders, doors, hood, and trunk lid are made from high strength aluminum. The rest of the body is steel.
The following 2 users liked this post by DaveW68:
Magnus Rostadmo (08-07-2017), Welwynnick (08-07-2017)
Old 08-07-2017, 03:04 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
My front wings(fenders) are 100% plastic.
Old 08-07-2017, 03:05 PM
Welwynnick's Avatar
2006 S600
Then you should get the S600. The 5000 lb curb weight doesn't mean squat when you've got 613 lb/ft of thrust and a zero to 60 time in the low 4's while being coddled in ultimate comfort, quiet, and every bit of automotive technology known to man when introduced. Plus, if you really want to go crazy, you can send your ECU over to Eurocharged to pump the HP up over 620 and torque to around 750 for just over $1k.
I think you just nailed my plan!
Old 08-07-2017, 04:04 PM
DaveW68's Avatar
2015 S550
Doubtful....unless your car suffered previous front end damage and the body shop put cheap garbage parts on it. The W221's all came with aluminum front fenders from the factory.
Old 08-08-2017, 05:52 PM
Welwynnick's Avatar
2006 S600
I've been resisting buying a W221 for several years - would never even consider it until recently, and was starting to look at other makes instead.
And then something like this comes up for sale, and I can feel the resolve weakening......
http://www.aspirespecialistcars.co.u...01708017932976
Old 08-08-2017, 11:40 PM
DaveW68's Avatar
2015 S550
That's a beauty!
Old 08-09-2017, 05:13 AM
  #32
You are correct. Too much Gin was making me think of my 215 :p
Old 08-10-2017, 03:06 AM
  #33
w2830's Avatar
2013 S550(W221)
Comparing my CL55 vs my 221 S65
3. Much quieter. the 221 was quietest in its class, surpassing Bentley and Rolls-Royce at the time.
Interesting. I've seen people saying that the noise level of w221 is subpar in comparison with the rivals. Actually worse even than the BMW 5 series. From my own experience, I'd have to say I'm not impressed at all with my newly purchased 2013 s550 in this regard. Could it be the tires? What's the quietest tires one would recommend for this car by the way?
Old 08-10-2017, 02:40 PM
  #34
Welwynnick's Avatar
2006 S600
I guess you're not using 255/45/18 tires?
If you were, you'd probably find the car quiet.
It matters what tires as well. Modern tires are really good at road noise. Every sporty street tire has gone asymmetric - there are no directional tires to be seen any more.
Nick
Old 08-10-2017, 03:07 PM
  #35
Super Moderator
Wolfman's Avatar
Received 3,282 Likes on 2,040 Posts
The interior and seats are in very good shape for a 100k+ miles car, but i would look for a lower mielage example. At minimum make sure that the engine had mounts, plugs, ignition coils swapped and the ABC history
Old 08-10-2017, 03:40 PM
  #36
w2830's Avatar
2013 S550(W221)
Nick
I'm pretty sure they're 19s. It has the AMG package. Anyway, I'd think19 should not sacrifice too much on the noise level or ride quality given the size of the car. I had 19s on my "tiny" 08 BMW 3 series couple which I don't recall having a noisier cabin on the road.
Old 08-10-2017, 04:04 PM
  #37
DaveW68's Avatar
2015 S550
That's strange. My S600 with a V12 bi-turbo motor and staggered 20 inch wheels shod with Hankook Ventus S1 Noble2 is pretty darn quiet. The quietness easily rivals my previous Lexus LS460. These cars have double paned glass on the sides and lots of sound deadening in the doors, firewall, and under the cabin. If you have rear A/C controls, you may want to check and make sure that they are turned off as that can make the cabin pretty noisy, as well as the fans from the ventilated seats. The front blower can also get a little noisy if turned way up.
Regarding tires, don't be afraid to run a staggered set-up as that will not add more road noise. Most touring style tires with fairly closed tread blocks on the outside of the tire are pretty quiet. But the more closed off the tread blocks, the less water and snow that get pushed away in inclement weather.
dlafever (08-10-2017)
Old 08-10-2017, 06:11 PM
  #38
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
I have the 19" staggered setup from the factory sport option. The tires that came with my car (used purchase) were some Sumitomo junk and it was as if the car 'knew' that just wasn't right. I measured the interior noise at 70mph @ 64db using an SPL meter. I recently put a set of Michelin Pilot Sport A/S 3+ on and remeasured the SPL again, this time 60.5db. It's amazing how much better the ride is, but I knew that would be the case.
Old 08-10-2017, 07:27 PM
  #39
compaddict's Avatar
2016 S63, 2013 SL63
I'm running Sumos on stock twenties and I don't get to much tire noise. I do get some though. Between that and coming from eighteens on my S55 might be the difference I hear.
Vince
Old 08-11-2017, 11:37 AM
  #40
Welwynnick's Avatar
2006 S600
Absolutely not worried about all those parts. I see them as consumables, and can repair or replace all of them.
That car is quite high mileage, but it's obviously been looked after, and the owner's preserved all the things that I wouldn't replace!
Nick
Old 08-11-2017, 02:25 PM
  #41
mdnx's Avatar
Infiniti/Toyota. Aspiring for Mercedes
Although it is a sad sight to see and I dont endorse any kind of behavior in this video, it really shows how well engineered the S class is considering how far it went.
Old 08-11-2017, 02:47 PM
  #42
compaddict's Avatar
2016 S63, 2013 SL63
That was entertaining!
Old 08-13-2017, 03:59 PM
  #43
Nuru's Avatar
S350 BT 4MATIC
I run CONTINENTAL EXTREMECONTACT DWS 06Ultra High Performance All-Season 255/40ZR19 100Y XLs, and my car is quiet, very quiet.
Old 08-22-2017, 07:20 PM
  #44
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
Exterior wise
#1 w222
#2 w220
#3 w140
is my opinion
Quick Reply: W221 a great S class series?
