W221 ANDROID touchscreen...
Old 11-26-2019 | 12:56 PM
  #326
BOTUS's Avatar
S500
Originally Posted by alexanderfoti
Hi all
Was there any update on a RHD version?
Such a shame, but theres LOADS of these in the UK that would give a big potential audience.
Originally Posted by Chris The Swede
Dont think it will ever happen..To small market.
far bigger than you might think
Australia
New Zealand
South Africa
India
Japan
United Kingdom (England, Scotland, Wales, N Ireland) and S Ireland
all drive on the correct side of the road, alongside 35% of ROW, and they probably bought more W221 between them than all other markets
Old 11-26-2019 | 12:57 PM
  #327
domr's Avatar
2008 AMG S65
Australia
New Zealand
South Africa
India
Japan
all drive on the correct side of the road, alongside 35% of ROW, and they probably bought more W221 between than than all other markets
RHD versions of this unit are now available.
BOTUS (11-26-2019)
Old 12-03-2019 | 03:32 PM
  #328
domr's Avatar
2008 AMG S65
I have a few updates to report after spending some time with this:
I added a wireless carplay dongle via one of the USB cables. It's a big improvement. No more messing with my phone's hotspot every time I wanted to use apps. Just turn on the car and carplay starts working.
In the stock setup, I could never get my reverse camera to engage. But I verified the camera was working via SDS. So I spliced the wires from the command plug for reverse camera video to an RCA cable and connected to the rear cam RCA plug of the android unit. It works well enough, and although I don't have anything to compare it to, I have to think it's better than having the android unit automatically switch back the the COMAND rear-view screen.
I've had complaints from people over the phone that the microphone doesn't work well. Looks like it's a small hole on the front bezel of the screen. I'm going to look for alternatives, maybe a USB microphone? Anyone tried that?
Old 12-03-2019 | 11:55 PM
  #329
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
I don't have phone issues I use the original command for phone calls, the camera splice I also did, but you didn't have to, I did it for the better RVC screen, but you can also change the camera choice in the android to OEM camera and it will switch when in reverse.
Old 12-04-2019 | 01:23 AM
  #330
redline's Avatar
2008 S63
Has anyone installed this in the Seattle area, and if so - is there a preferred shop for the installation? I wouldn't date attempt myself.
Old 12-04-2019 | 01:54 AM
  #331
I've installed a lot its not hard but not for the faint heart either depending on your car may also need some coding and wired mod, so the shop must be prepared for this...
last install
View this post on Instagram
Old 12-04-2019 | 01:55 PM
  #332
Mercedes-w221's Avatar
w221 2007
last install
https://www.instagram.com/p/B5MN9Hah..._web_copy_link
I have been looking at this screen and thinking of buying one , have one questing , does the screen also auto dim when turning dark like the old screen and ic cluster ?
Old 12-04-2019 | 03:00 PM
  #333
here’s some samples if they can help
https://www.instagram.com/s/aGlnaGxp...52743922230315
https://www.instagram.com/s/aGlnaGxp...82637892634946
Old 12-05-2019 | 12:20 PM
  #334
domr's Avatar
2008 AMG S65
last install
I saw on your instragram a video of carplay being controlled by the comand knob. Any insight on getting that setup?
Old 12-11-2019 | 12:09 PM
  #335
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Does cellular data works with those displays? I put T-Mobile sim card to my unit, but I can't get connected to the network.
Old 12-11-2019 | 12:12 PM
  #336
400ixl's Avatar
E250 AMG Sport Convertible
Depends on where you are and whether the mobile bands are covered for your provider. In the UK I have a mobile sim running fine.
Old 12-11-2019 | 12:16 PM
  #337
domr's Avatar
2008 AMG S65
I assume you're in the US so the answer is no. At first I was tethering via wifi with my iphone. That wasn't very reliable. Recently I bought a mobile router, connect to it via usb with the iphone to tether, and the android screen connects to the router via wifi. The router is usb powered so it's great for a car application. It's been much more reliable this way, and provides wifi for the rest of the car passengers as well.
https://www.amazon.com/gp/product/B073TSK26W/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B073TSK26W/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Old 12-13-2019 | 01:18 AM
  #338
Agent Seattle's Avatar
W221 s600
I'm also in Seattle and would appreciate a local recommendation.
Old 12-18-2019 | 04:53 PM
  #339
Orion81's Avatar
Mercedes Benz CL500 C216
Hello I have a C216 facelift (NTG3.5) with TV. I can see AUX and USB options in my unit but I cant figure out where the ports are
My questions are:
  1. Will it work on my car?
  2. Does it use the car microphone array for calls? And obviously speakers?
  3. Can anyone verify the hardware specs for the unit?
  4. Can it use the GPS antenna that is built in the car instead?
Old 12-18-2019 | 05:09 PM
  #340
artim808's Avatar
White and red RCA should be your audio input.
1. Yes
2. You can use either car microphone or display microphone for calls.
3. There are different hardware versions. Post link you're interested to purchase.
4. Not sure about that, but included GPS antenna which come in the package with display is surprisingly very good.
Old 12-18-2019 | 06:07 PM
  #341
Orion81's Avatar
1. Yes
Can you confirm the hardware specs of the unit please? Are you experiencing any lag in the UI like elements freezing for a second or two etc?
This is probably the unit i am getting http://www.ckmcardes********/cl/c216...ouchscreen-rhd
Old 12-19-2019 | 07:15 PM
  #342
domr's Avatar
2008 AMG S65
There is a cable referenced earlier in this thread that allows you to tap into the car's GPS antenna signal.
Old 12-20-2019 | 04:41 PM
  #343
Ninamashr's Avatar
2010 S550 Black on Black
https://www.ebay.com/sch/i.html?_fro...tra+c&_sacat=0
here's the cable you can install if you want to use the Mercedes GPS antenna
Old 12-20-2019 | 04:43 PM
  #344
Ninamashr's Avatar
Old 12-24-2019 | 01:29 AM
  #345
you need to configure it in the host application, its a lil tricky but once it works its good
Old 01-02-2020 | 02:03 PM
  #346
domr's Avatar
2008 AMG S65
Has anyone had luck with an OBDII BT adapter and an app like Torque? From what I've gathered, the android build is crippled to exclude use of BT devices other than phones.
To follow up on this, I ordered a usb ELM327 adapter which works fine with this screen and the Torque Pro app:
Amazon Amazon
Mustafoinc (11-14-2020)
Old 01-02-2020 | 04:33 PM
  #347
artim808's Avatar
Does this work even if you use USB hub? I have bluetooth ELM327 adapter, but I'm getting error message for incorrect PIN/password. Screen never ask for PIN/password, for some reason once I select OBD adapter to pair I get incorrect PIN/password message. I don't know if there is different way how to pair the adapter with the screen.
Old 01-02-2020 | 04:36 PM
  #348
Kevo79's Avatar
s63
Can anyone give me a reputable place to buy one from. I own a 2011 s63 and I absolutely hate this radio it so old looking it kills the vibe lol. But seriously where can I buy and what all would you guy’s recommend me buying with it as far as wire kits and any other notes. Any help is greatly appreciated. I live in Maryland so anywhere in the dmv that would be able to install as well would be appreciated
Old 01-04-2020 | 03:03 PM
  #349
Dhaif's Avatar
W221 s550
No sound issue FIXED.
My car is s550 2006 JAPANESE imported.
I ordered this screen from China and they emailed me the instructions and diagrams.
Jp imported usually came with tv and no AUX, so the seller asked me to follow the TV diagram. I connected as instructed but no sound.
Sent him pics and we Scyped to set up again but nothing. He consulted with their engineer and replied that JP tv in the unit can not accept the android TV box so try to find the AUX cable behind fuse box or below gloves box. But there is no cables there. So I gave up and sent my car to a guy who always installs android for all kind of cars and take him less than 5 min to fix it.
If you have a car like my model so here are the steps:
1- program the c unit to activate AUX function.
2- there will be three harness came with screen to have audio (none worked for me).
3- the electrician guy pulled three wires out of the aux harness (red, black and white) that driginate from the screen and connected them to three blue wires in the (aftermarket) power caple. Which are they? Actually, I could not see that clearly when he did them but I was sure that he did not cut any of the original wires.
Old 01-04-2020 | 03:10 PM
  #350
Dhaif's Avatar
W221 s550
I guess they are all made by one manufacturer but they got sold by resellers on Aliexpress.
Mine costs 680$ to my door in 5 days.
Kevo79 (01-09-2020)
Quick Reply: W221 ANDROID touchscreen...
