W221 ANDROID touchscreen...
Old 07-14-2018, 01:19 PM
  #76
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Originally Posted by Ninamashr
This looks fantastic!!! So is it a touchscreen only or can it be controlled with the Command controller? Since the screen is inside where the original screen was, it might be a little far to safely reach in while driving. It's not a deal breaker for me, but, just asking.
IT IS A TOUCHSCREEN TOO.
Old 07-14-2018, 04:55 PM
  #77
EasyPhil's Avatar
2007 S550 4Matic
I have no problem hitting the radar sensor or vehicle rise button right next to the display so the touchscreen shouldn't be a problem.
Old 07-15-2018, 02:31 AM
  #78
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Originally Posted by SpirosMika
Hey Chris, are there installation instructions included? What about the retrofitted reverse camera? Will it work?
No but its ver simple. And there are many videos on you tube on how to remove the old unit. Settings insctructions is included.
Old 09-10-2018, 06:32 AM
  #79
Tarek Fahmy's Avatar
W221 / W211 / W202
Hey Chris, we need to here from you . . . . what's your feedback on the W221 Android Touchscreen ???
Old 09-10-2018, 06:42 AM
  #80
Good so far.
Old 09-10-2018, 07:04 AM
  #81
W221 / W211 / W202
Congratulations & Good Luck
But does it support the original W221 vehicle menu ?? such as seat menu, Interior Ambient Light,Exterior Lighting Delayed , Automatic Locking, Convenience Settings . . . etc.
Is there any thing not supported or not working with it ???
Thanks.
Old 09-10-2018, 07:16 AM
  #82
As said so many times..Its a screen...ALL old settings is still on old comand. Of course also Showing on this new screen.
The following 2 users liked this post by Chris The Swede:
Kwarior (08-31-2020), Tarek Fahmy (09-10-2018)
Old 09-23-2018, 06:07 AM
  #83
xuan lam ngo's Avatar
s500 w221
please help me circuit diagram. thank you. gmail: xelamso5@gmail.com
Old 09-23-2018, 06:15 AM
  #84
400ixl's Avatar
E250 AMG Sport Convertible
Wiring diagram for what element? Its all plug and play with the supplied looms. What else are you trying to do?
Old 09-23-2018, 06:36 AM
  #85
Exactly..
Old 09-28-2018, 04:01 AM
  #86
s500 w221
Originally Posted by Chris The Swede
And I FINALLY got them to do mph and farenheit for you...
anything ok. but not sound
Old 09-28-2018, 06:38 AM
  #87
Then you have done somethng wrong installig it or setting it up-.
Old 09-28-2018, 08:55 AM
  #88
lionsfan54's Avatar
Mercedes Benz S600
Did I miss something? Is this now for sale?
Old 09-28-2018, 09:00 AM
  #89
For months...
lionsfan54 (09-28-2018)
Old 09-28-2018, 09:02 AM
  #90
lionsfan54's Avatar
Mercedes Benz S600
For months...
link?
Old 09-28-2018, 10:05 AM
  #91
I cant do links. I get banned then...PM
Old 09-28-2018, 01:31 PM
  #92
Ninamashr's Avatar
2010 S550 Black on Black
Just a simple question. Can the color of the Mercedes on the screen be changed from white to black??
Old 09-28-2018, 01:41 PM
  #93
No. Not even in OEM screens this can be done .
Old 09-28-2018, 07:36 PM
  #94
Bmccann101's Avatar
2007 WALD Black Bison S550 4matic
Hello Chris, New 2007 s550 owner here, as of today actually lol.. I've PM'd you. Very excited to see this is actually possible.
Old 09-29-2018, 02:52 AM
  #95
I answered..
Old 09-30-2018, 12:55 PM
  #96
PillDrive's Avatar
2003 S55 (SOLD) , 2012 S550
Hey Chris,
in the youtube demo of the screen i saw that there is an option for an SD card. Is that seperate from the command usb/sd card reader and if so does it support a large card since the command does not work well with 32+ gb sd-cards or usb flash drives. Also what gps software comes with it ? Since it is android based can i just get any gps software i like and integrate it?
Thanks.
Old 09-30-2018, 01:06 PM
  #97
400ixl's Avatar
I have the unit which is external (as in tablet form) as its in a C207. The SD slot on that is part of the main unit behind the screen and I have a 32Gb card in it, someone else has put a 128Gb card in theirs. If this is in the same place, it would be behind the cover, so in the dash in this type of fitting. Mine has two USB connectors which will take 32Gb or bigger USB flash drives.
The GPS software that comes installed from Chris is copilot, although this did not work on mine with an error when launching. Never got a response when I asked what was needed to fix it (re-install it as its different to the Play store one) but not too much of an issue as I use Waze or Google Maps for online and Navigator for offline. You can change the navigation shortcut to whichever app you want. Its the only one of those icons you can change what app gets launched though. Video and Music are fixed to what they supply, although you can launch anything else you install from the apps folder.
Old 09-30-2018, 01:37 PM
  #98
PillDrive's Avatar
Thank you for this answer 400ixl.
So i take it you are satisfied with the unit ?
  #99
Jason B's Avatar
Ok, so I have a custom font camera on my w221. When below 5 mph, it comes on automatically. Would this still work with this setup? It's hooked into the command plug, way below the display area, and it uses the same trigger that the reverse cams uses, to do the front cam.
Old 09-30-2018, 01:50 PM
  #100
400ixl's Avatar
Overall yes, still a couple of things I would like to see done differently in the firmware. Main one being that like many Chinese units they have blacklisted a lot of the OBD2 dongles meaning only the expensive ones work for things like the torque app. Would like to see that removed and save me having to root it an remove that restriction myself.
Quick Reply: W221 ANDROID touchscreen...
