Can't set date and time in Comand
Old Oct 30, 2019 | 02:21 PM
  #51
BOTUS's Avatar
S500
Originally Posted by Polar Bear
OK, read about it now.... wow, well done and thanks for all the work you guys have made on this update disc,
I was going to say this must be very new, as I had mine plugged in last week and there wasn't one showing up... we are still trying to fix a bug with the radio not muting when a Nav comand cuts in. Used to do it perfectly... and after running round the houses, its all pointing to Mercedes informing us to update the Rear SAM with SCN pulling in a facelift update from week 43 in 2009 that's broken it
FYI something seems to have given me hill hold assist (vehicle has distronic plus), I notice it if reversing up my drive and I brake (to double check what's about) it will hold the brakes on and not roll forwards down the drive for around two seconds. never did that till we updated some stuff this year
Old Nov 7, 2019 | 05:00 PM
  #52
Pitek's Avatar
06 MB E350 4Matic Sedan, 08 MB S550 4Matic Sedan
Thumbs up It worked!
Hi Polar Bear and your team,
Thank you for your persistence in solving this on-going problem.
I followed to a T your very detailed and specific instructions.
It worked perfectly! Wow!!
I gratefully appreciate it.
Thank you again,
Pitek
Old Nov 9, 2019 | 01:57 PM
  #53
Mercedes-w221's Avatar
w221 2007
I also did the update and it works but the star is showning fail on command and says wrong software for the comand , how about you guys ? also have fail in star fault read ?
Old Nov 9, 2019 | 05:16 PM
  #54
Pitek's Avatar
No problems
As I wrote earlier; it works perfectly!
Thanks,
Pitek
Old Nov 9, 2019 | 05:44 PM
  #55
w221 2007
so you have read out codes whit das after the install, and there is no fault in das ?
maybe couse im in europe , the update and date and time work, but das says its wrong software , but it works
Old Nov 10, 2019 | 07:18 PM
  #56
Pitek's Avatar
I am not sure
Hi Mercedes-w221,
No, I have not read the codes with DAS. I do not have one and the stealership charges an arm an a leg to have anything scanned here in Canada. I refuse to go there! Period.
I will have an access to a pretty good scanner this week. I will find out if there are any codes. But, I am not sure why it would be so important to anybody at this point. It does work like a charm.
Thanks,
Pitek
Old Nov 10, 2019 | 11:50 PM
  #57
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
That message is benign - please see my response in the other thread.
Thanks!
Old Nov 15, 2019 | 05:16 PM
  #58
Pitek's Avatar
Originally Posted by Pitek
Hi Mercedes-w221,
Thanks,
Pitek
Hi Mercedes-w221,
I promised to have my car scanned. Yes, there is an error message about the software. But you know what? I really do not care.
Why? Because, as I had already said twice "it works like a charm!" I am happy and very grateful to Polar Bear for the permanent fix.
Thanks,
Pitek
Old Nov 16, 2019 | 01:10 PM
  #59
Bklyn's Avatar
S550
Originally Posted by Volkl158
Hello everyone. Long time lurker, occasional poster. Here is my problem:
I can go through the Comand Center and get into the Time. I can move the time to the correct time, but when I click on the center of the Comand Button to confirm it takes me back one screen to the Time and does not update the clock. The same exact thing happens with the Date. I can update the Date to today's date but when I click in the Center to confirm it takes me back to the previous screen and the date goes back to 04/10/2018. I have no errors and everything else if functioning correctly including the working clock...it's just off an hour. I even tried to change it from Eastern Time to Central Time and it does not update, it just goes back a screen.
I understand your problem. I have been trying to set my clock back since DST and so far have been unable to do it. Truth be told, it makes me CRAZY.
Old Nov 16, 2019 | 07:40 PM
  #60
chriswhv6's Avatar
2010 E350 Cabriolet (A207), 2007 (MY08) S350 W221, 2013 ML350 BT W166
I managed to set the time using the 24hour sleep method plus undercover parking (to help reduce GPS strength) and i managed to set the time finally.
The only thing ive noticed though still is the calendar date won't change that's reverted to 2003 and i think the clock has fallen behind 2 mins in time.
Honestly i don't care for the date being incorrect and just happy i was able to fix the time as before it was over 30/35 mins difference if i remember correctly.
Old Nov 16, 2019 | 10:28 PM
  #61
Bklyn's Avatar
S550
Interesting. I have exactly the same date in 2003 stuck and am unable to change it.
Old Nov 17, 2019 | 04:31 AM
  #62
BOTUS's Avatar
S500
use polar bear's 10 minute update cd works perfectly - clock goes back to working as it did the day it left the factory (as does the nav unit)
Old Nov 19, 2019 | 12:12 AM
  #63
ArtieK88's Avatar
S550
Thanks, that just worked for my 2007 S550!!!
Old Jan 9, 2020 | 06:21 AM
  #64
OdysseusVL's Avatar
Mercedes-Benz S-320 CDI W221
Hi Kunzy80,
Sorry for my very late reply, but I didn’t just come around to testing your solution.
Plus my S 320 has been stalled for a long time as I did not have the money available to repair the oilcooler leakage for which these W221’s are infamous of ;-(
Anyway this has now been repaired ( yeah!! ) and I tested your solution.
Good news! It worked like a charm! For me the easy part was that I have a garage in my house where I park my car when not driving, so I didn’t have to hurry putting the date and time as my car does not have access to the GPS network when it’s inside LOL
Thanks a million for your help as this problem was bugging me for a longer period already, and even worse no MB dealer in entire Belgium did know a workaround or solution. Tssssssssssssss....
Cheers and take care dude
Wilfred
Old Mar 15, 2020 | 04:51 PM
  #65
Vernon Vaughan's Avatar
c200 kompressor coupe
Thanks will give it ago and let you know cheers
Old Aug 8, 2020 | 10:29 PM
  #66
gambari's Avatar
05 E55, 08 S63, 09 GL450
Thank you...
Originally Posted by kunzy80
Hi Wilfred
I have 3 Mercs in My Garage = A GL63/S550/E500
im not going anywhere by leaving this Forum - which has saved me soo much time ;-P
Now coming to your concern - i was able to fix mine and here are the steps
Step 1 - Tonight before sleeping and letting your S go to sleep - switch off Command till the screen is completely off
Step 2 - First thing in the morning - you have a very small window ( approximately 60 seconds ) do the entire process as fast as you can , as its imperative to make the changes before the command syncs with the GPS Sats
Step 3 - Switch Key to position 1 or press start button once - till your ignition lights - light up in the dash .
Step 4 - Switch On Command - Navigate to the Date & Time Settings in the command - and quickly make the changes ( took me 33 seconds - Like a NINJA - lol )
Step 5 - At this point your time and Date should adjust - and you should be good to go
Its been over a month and mine has been working just fine
Let me know if you need anything else
Good Luck
This is what I love about this forum; no matter how along it takes for you to have weird issues with our cars, you will find someone who has figured it out. This issue as described by others was bugging the heck out of me but I tried the solution offered by kinzy80 and like magic, problem solved. Thanks for that.
Old Aug 9, 2020 | 05:08 AM
  #67
BOTUS's Avatar
S500
you've picked up the wrong post and the wrong fix (that's a nasty work around - the correct software fix by polar bear and his colleagues did what Mercedes didn't bother with)
https://mbworld.org/forums/s-class-w...ml#post8016600
post 137 has the file, inside 30 mins of reaching here you could have fixed the car correctly... if you have a cd burner and know how to use it
Old Aug 9, 2020 | 09:03 AM
  #68
DaleB's Avatar
Veteran: Army
2007 S600
Indeed.
Old Aug 9, 2020 | 11:31 AM
  #69
Thumbs up
cheers will give it a shoot
0
Old Apr 23, 2024 | 12:24 AM
  #70
Marcus Duffner's Avatar
ML55 AMG, CL65 AMG, G63 AMG
Smile
Hi Wilfred
Good Luck
Many thanks for the hint. It drove me crazy, setting the date and seeing it jumping back every time. I do have a Android head unit and the date changed there as well. Tried all possible settings to avoid the date to change.
I have reset the date as you advise. Rechecked 15 min later and its still there. After the breakfast I will go to the GYM taking the CL65 for a ride. Lets hope the date won't change anymore.
BR Marcus
Old Apr 23, 2024 | 04:29 AM
  #71
BOTUS's Avatar
S500
this entire thread is drivel
all the satellites up their moved their clocks from year 19 to 1 - in April 2019, in a standard event know as WNRO - GPS devices impacted by the issue can be fixed by applying a patch letting the device (aka your comand unit) know what 19 year epoch its working in
for devices running NTG3.0 a user make-able CD will fix the time and date bug now inside your car inside 10 minutes - read the correct post here
https://mbworld.org/forums/s-class-w...ml#post8468441
