Can't set date and time in Comand
I can go through the Comand Center and get into the Time. I can move the time to the correct time, but when I click on the center of the Comand Button to confirm it takes me back one screen to the Time and does not update the clock. The same exact thing happens with the Date. I can update the Date to today's date but when I click in the Center to confirm it takes me back to the previous screen and the date goes back to 04/10/2018. I have no errors and everything else if functioning correctly including the working clock...it's just off an hour. I even tried to change it from Eastern Time to Central Time and it does not update, it just goes back a screen.
Hello Volk - i have the same identical problem - any luck on your end ?
any help would be greatly appreciated
thank you again
it means just when the dash lights are on ?
i tried every single thing - but this is exactly whats happening on my end
"I can go through the Comand Center and get into the Time. I can move the time to the correct time, but when I click on the center of the Comand Button to confirm it takes me back one screen to the Time and does not update the clock. The same exact thing happens with the Date. I can update the Date to today's date but when I click in the Center to confirm it takes me back to the previous screen and the date goes back to 05/03/2003. I have no errors and everything else if functioning correctly including the working clock...it's just off an hour. I even tried to change it from Eastern Time to Central Time and it does not update, it just goes back a screen."
if you were able to sort yours out
im hoping your technique will help me out as well
i think ignition position one might work because you haven’t synchronized to the satellite yet.
and yet no luck
any other ideas ?
my date doesnt change
and the clock in the command shows the right time
only when i change the time on the command clock - it doesnt change it on the analog which is on the front console
If the GPS antenna can be disconnected maybe that works.
I thk it it worked for me maybe because it didn’t have time to synchronize.
I hope you are still a member and see this reply from me.
Besically I have now exact the same problem as you describe in this post in my S-320 CDI W221 from 2008 model 2009.
I cannot reset my front clock through the command, and the date in the command is incorrect.
When I try to change the time and the date, it brings me back to the first screen like you explained and it does not keep the correct date.
Time is correct in the command, but it does not sync my analogue front clock.
Did you ever receive a solution for this problem?
Wilfred
I have 3 Mercs in My Garage = A GL63/S550/E500
im not going anywhere by leaving this Forum - which has saved me soo much time ;-P
Now coming to your concern - i was able to fix mine and here are the steps
Step 1 - Tonight before sleeping and letting your S go to sleep - switch off Command till the screen is completely off
Step 2 - First thing in the morning - you have a very small window ( approximately 60 seconds ) do the entire process as fast as you can , as its imperative to make the changes before the command syncs with the GPS Sats
Step 3 - Switch Key to position 1 or press start button once - till your ignition lights - light up in the dash .
Step 4 - Switch On Command - Navigate to the Date & Time Settings in the command - and quickly make the changes ( took me 33 seconds - Like a NINJA - lol )
Step 5 - At this point your time and Date should adjust - and you should be good to go
Its been over a month and mine has been working just fine
Let me know if you need anything else
Good Luck
Worked great thank you for resolving this annoying problem
QUOTE=kunzy80;7696959]Hi Wilfred
Good Luck[/QUOTE]
2. Visited my local MB stealership. They could use their scan/diagnostic tool and do it for only... 199.99 CAD plus 13%. I am not an idiot!
I will patiently wait for the FREE (e.g. recall?) permanent solution.
Without the opportunity to physically inspect the vehicle, the Service Manager at your local authorized dealer would be in the best position to make the necessary recommendation in this regard.
For your convenience the information to your closest Mercedes-Benz dealership is provided below:
Mercedes-Benz Dealer Locate
We apologize we could not be of further assistance, and solicit your understanding of our limitation in this matter.
Mercedes Benz USA
(800) 367-6372
I have always loved to play chess since I was a kid. This royal board game taught me analytically thinking and foreseeing opponent's moves.
I foresaw their next move - back "to your closest Mercedes-Benz dealership." I went to visit them BEFORE they offered me their overcharged service.
Again! Come to us and we will for free clean out your wallet with a big smile on our faces and pretending to do everything for you... The usual and typical.
And the unresolved problem still remains... Nothing new.
Hopefully the world will stop using DST in the future.. I have 3 Mercs in My Garage = A GL63/S550/E500
Good Luck
So, 999 weeks / 52 weeks per year = 19 years. I can live with that.
Thanks,
Pitek
