Heated steering wheel doesn't work
2014 CLS 63 S AMG / 2004 E55 AMG
The heated wheel doesn't work on my newly purchased 2012 S63. The light on the stalk comes on, but the steering wheel doesn't heat up at all. Does anyone else have this issue, or solved this issue? Any help is appreciated.
Thanks, I found that out after posting this thread. The leather section still doesn't appear to get warm though. Is the heating noticeable, or is it very subtle?
I poked around in the SAM fuses, etc, and it doesn't look like an obvious repair. Has anyone repaired their heated wheel? I'm curious what parts were replaced or repaired.
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
Can anyone confirm if a relay should open or close in the SAM when the heated wheel is engaged? I don't hear anything, but I do hear a relay when I move the wheel position.
2007 S550 4Matic 2013 S550 Base
I would check to see if the heating connector is attached which will require removing the air bag and using STAR to clear the resulting fault code.
Yes, it was unplugged (no clue why). Disconnect the battery and take part the steering wheel to see the plug. I forgot if you have to unplug the airbag to get to it, but if you do, keep in mind that the car will throw an airbag code even if you unplug it with the battery disconnected.
No fuse operated direct by front SAM, read through attachments previously posted: https://mbworld.org/forums/s-class-w...ml#post7631670
the ONLY package that makes sense is the BenzNinja setup... the rest is just virus infected old junk, no info on the right VCI and its so mad you'll never understand how to do anything in the exciting arena with any merc - the value is the support ( the tool on its own is more or less useless - and no huge community of how, like there is for other brands - and even if you think there is - the reality is its just liars and fools keeping all the knowledge to themselves - the only thing with BMW, is 100.000 people have all tried before you and across 6 different forums and after year's worth of research you have a small clue on how to tackle some of the most simple jobs like enabling Bluetooth )
he advertises on this forum nearly every week...
https://mbworld.org/forums/s-class-w...ce-coding.html
I don't think he does Personal Messages on the forum... he has a job to do fixing 99.9% of every merc ever made (as the dealers certainly don't have a clue)
in post 2, konigstiger shows a load of documents about the operation of the heated wheel - aka - SA Code 443 HEATED STEERING WHEEL
if you use a tool like this https://www.lastvin.com/ it lists that optional extra on cars that have it... But I can't find 443 in Xentry under a list of features on the car.
please could someone with this heated steering wheel option please scan their CGW and see if Lenkredheizung or Heater steering wheel is listed... and if so please post any info about which CGW is on your car with the Software its running
I can't find this option in my CGW which is
CGW - Central gateway
MB number
2215408945
HW version
05.42
SW version
07.05
FW number
2214480527
2214481327
parts of the car involved in the heated wheel....
A74 Steering wheel heater electronics
B10/4 Interior air temperature sensor
N10/1 Front SAM control unit with fuse and relay module
N22/1 AAC [KLA] control unit
N73 EIS [EZS] control unit
N80 Steering column module
N93 Central gateway control unit
S59/1s2 Steering wheel heater switch
MB number
2215408945
HW version
05.42
SW version
07.05
FW number
2214480527
2214481327
Heated steering wheels are one of the more useless features carmakers have come up with along with headlight washers. If it's 20 degrees out, anybody with common sense is going to be wearing gloves.
