Brake Rotors 2013-S550 - Q for Konigstiger
Old Jan 6, 2019 | 06:40 PM
IvanP's Avatar
2013 S550, 2012 GL550
I will be changing pads/rotors on 2013 S550 and cannot find definite answer for size of the rotors and part Nos.
The car has option 951 - sport package (WDD2211731A498119) but I am not certain if that is the same as the AMG sports package that some vendors of brake discs are referring to. Current rotors are drilled on the front, smooth on the rear.
I found two different part numbers: 221 421 16 12 and 221 421-18-12 not sure what is the difference (size??) I am thinking about going with coated rotors to prevent rusting but need the dimensions to get the right part.
Thank in advance for any help available.
Regards,
Ivan
Old Jan 6, 2019 | 06:53 PM
PillDrive's Avatar
2003 S55 (SOLD) , 2012 S550
221 421 16 12 is the correct one for your car
Old Jan 7, 2019 | 10:39 AM
konigstiger's Avatar
'71 Pinto
Front disk OEM 2214211612, pads 0044208020, wear sensor 1715400617; rear 2214231012, 0064200120, 2115401717. Search OEM part # coated.
Old Jan 8, 2019 | 10:34 AM
IvanP's Avatar
Thank you!. Much appreciate the guidance you provide.
Regards,
Ivan
