Brake Pedal Rubber
Old Feb 27, 2019 | 01:44 PM
Bklyn's Avatar
S550
Brake Pedal Rubber
He all, I know that this is not a very sexy topic but I need to replace mine as it is totally worn through.
Dealership wants about $35.00.
Should I walk in and get one or should I look around on Amazon?
Old Feb 27, 2019 | 02:26 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
For $35 you may as well pay yourself on the back that you ever got outta the dealer for that. How are my rims?
Old Feb 27, 2019 | 02:27 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
If it's the part I'm thinking of it is 123 291 00 82
FCP Euro has that for https://www.fcpeuro.com/products/mer...pad-1232910082, for;
Price each:$3.37
Even though their catalog does not show the W221 as compatible, the Meyle (OEM) says it is;014 029 0001Comparison numbers 123 291 00 82 MERCEDES-BENZMEYLE-ORIGINAL QualityAutomatic TransmissionUtility no.:
MIX0002
Old Feb 27, 2019 | 03:24 PM
1bad540's Avatar
s550 Diamond white amg pano
both mine hav been amg packs so mine have had the metal pedals... is yours straight rubber?
Old Feb 27, 2019 | 04:16 PM
Bklyn's Avatar
S550
Price each:$3.37
MIX0002
Thanks so much!
Old Feb 27, 2019 | 04:17 PM
Bklyn's Avatar
S550
Straight rubber.
Old Feb 28, 2019 | 02:50 PM
bha's Avatar
bha
13 GL350, 14 SL550
Very cheap online and can be replaced quickly
I think the aftermarket ones were $3 and real ones on eBay were about $7-8
I bought a real one because I'm sure the aftermarket was fine, but don't want to risk it. Difference is only a few $ anyhow.
One side wraps completely around the pedal and the other just barely wraps around. This second end that barely wraps is the first one to come off / last one to go on. You'll see when you get the new one. Unhook the smaller end and slide off the pad. Hook on the bigger end as you slide on the new, then hook on the smaller end. Basically look at the new pad and remove the old one the most logical way, then do the exact reverse to install the new one.
Takes 2 mins to install and car feels like new. My foot actually almost slipped off the brake once before, because I was touching only the metal of the pedal that had worn through the rubbere.
Old Feb 28, 2019 | 04:37 PM
Bklyn's Avatar
S550
Thanks! This is great info. Much appreciate it.
