iphone doesn’t connect
Old Mar 12, 2019 | 09:52 PM
yama11's Avatar
s550
I bought a 2009 s550. It has the Bluetooth module. It recognized my IPhone. Says it authorized it. But my iPhone does not show connected, and I cannot place calls. What do I need to do to correct this??
Any insight anyone can give me would be appreciated. I’ve searched and search, to no avail.
Old Mar 20, 2019 | 10:32 PM
yama11's Avatar
s550
anybody?????
Old Mar 28, 2019 | 01:56 AM
07CL550Benz's Avatar
2007 CL550
I'm curious about this too.
Old Mar 28, 2019 | 12:30 PM
yama11's Avatar
s550
From what I am gathering while researching this, is I think I need to buy a Bluetooth adapter. The car is equipped with the part in the console, but there is no adapter in the car. Does that sound about right, that I need to buy the adapter??
Old Mar 28, 2019 | 02:39 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
There are two Bluetooth connections possible without adding the adapter in the glove box. The only one that works for phone control will show up as MB PhoneSystem. I do not recall what the other connection's broadcast ID is but it's not useable. The MB PhoneSystem bluetooth adapter is in the center console and looks like this;
If you have the iPhone adapter cable in your glove box, you can add the Bluetooth adapter (e.g. Bovee, Viseeeo, CarPro etc.) It will need to connect as a second BlueTooth device and will allow you to stream music via the AUX input in COMAND. They typically look like this;
Old Mar 28, 2019 | 03:23 PM
BBanzai's Avatar
2008 S65 AMG
I believe that the Bluetooth connection in the COMMAND system doesn't actually do anything. Or at least not on my car. I can connect but can't use it. I think you have to buy the devices specified by dlafever to make calls and stuff. Weird.
Old Mar 28, 2019 | 06:32 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
I have both in my car, one for calls and one for streaming music, they work great.
Old Mar 28, 2019 | 08:00 PM
yama11's Avatar
s550
Thank you for the great info. I’m still a little unsure, so before I invest in anything, I want to make sure I buy the right piece. I only want the BT for making phone calls, I’m not too concerned about playing music. So for that reason, would I purchase the MB Phonesystem bluetooth adapter? Other than buying directly from Mercedes, is the next best place ebay? I really appreciate the help, this is our first MB, and after being Toyota owners for so many years, this is a learning process for us.
Old Mar 28, 2019 | 08:15 PM
tx170754's Avatar
Probably E-bay is your friend, just make sure you buy he right one, I may be wrong but, I guess, there are two models....
Old Mar 28, 2019 | 09:31 PM
yama11's Avatar
s550
How do I determine which is the correct one? 2009 S550.
Old Mar 28, 2019 | 09:39 PM
tx170754's Avatar
Go on E-bay there are a lot of Bluetooth adapters for your car....
