Anyone here did their own transmission fluid replacement? Dealer wants $572 !!!!!!!!
Old Mar 29, 2019 | 03:32 PM
andrewk-S550's Avatar
2013 S550 & 2024 Kia Carnival Prestige
Anyone here did their own transmission fluid replacement ? How difficult is this? does the car have to be level for this? otherwise I need 2 lifts.
Called some local shops and everyone says NO, Anyone in Northwest chicago suburbs that you can recommend ?
Thank you
Andrew
Old Mar 29, 2019 | 04:14 PM
ygmn's Avatar
2015 E400 Sedan
Did dealer break down price?
Like labor hours & labor rate?
How much oil, are they changing filter?
anything else?
Old Mar 29, 2019 | 05:43 PM
lkchris's Avatar
'10 CL550, '12 GL550
Trans fluid drains and fills from same hole ... special tool obviously required
Amount to use depends on temperature, so need temp measuring tool, too.
Old Mar 29, 2019 | 10:20 PM
Nuru's Avatar
S350 BT 4MATIC
Suction pumping tool, plus temp measuring tool.
Old Mar 30, 2019 | 12:17 AM
wilassasin's Avatar
2013 S550 4matic (AMG sport package), 2016 Corvette Stingray.
See if they are running any specials on service, check dealer website, and if not see if they can give a slight discount.
Old Mar 31, 2019 | 12:27 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Thank you
Andrew
This is one of the many reasons I bought a lift for my garage. It makes transmission fluid changes, driveline service (think the big rubber donuts) and many other jobs far easier and from my calculation paid for itself in the first 6 months of owning it.
An amazing dude with the handle of G-AMG posted a photo DIY for your transmission that he performed on his E350. You can get an idea of what is involved here;
https://www.benzworld.org/forums/w22...7g-tronic.html
Old Apr 21, 2019 | 11:53 PM
cetialpha5's Avatar
If you're looking for the fluid, try a Shell distributor. They should have Shell ATF 134 FE for around $65 for a case of 12 quarts.
https://www.shell.us/business-custom...r-locator.html
Old Apr 24, 2019 | 06:38 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I have a 2007 and my research here showed I needed ATF134...did my flush for $65 (Fluid) and $30 (filter gasket combo). There are videos and instructions here - just search and you will find what you need to do it.
Old Apr 24, 2019 | 03:16 PM
BBanzai's Avatar
2008 S65 AMG
You should replace the transmission connector while you're at it. It's cheap insurance.
Old Apr 25, 2019 | 11:49 PM
JohnLane's Avatar
222 S-65
Trans service is easy to do.... On a hoist.
Trans pan has a drain plug. Fill via the dipstick. Get a long skinny funnel for it.
I change my ATF every 10,000 miles. The transmission is more sensitive about fluid then seems possible.
Replace the filter every other ATF fluid change.
