intake air temperature V-12 (2008)
I have read other threads and saw that some had good luck with the Johnson CM30 pump to replace the standard Bosch. I dont know if mine has ever been replaced so it could be the old 3 gpm pump in there.
I would like to hear from anyone that has gone down this road ahead of me. This car ( S600 ) has the M275.
a 5 pence bodge up tune, by with-think-we-know-better - will push into the safety systems Mercedes created to stop pistons melting and stuff failing - sure on a cold damp morning before the car has reached melting point - a smidge more timing and a smidge more boost will feel peppier than Merc built....
but when ambient temps are high, and some one used 50% of its performance for 5 minutes the car starts getting hot and of course the engine management (before its been molested), will wind things back when temps and knock are starting to imped longevity
sure you can push it harder and sure you can buy a new engine next week -
Some fit an additional heat exchanger in front of the stack with a second charge cooling pump.
Water/Methanol injection is effective. Weistec makes a kit. Peter swears by it. It’s on my to do list.
