Please Help
1) What years I am looking into 2007 to 2009
2) What milage
3) What kind of mentainance I can do as DIY. I am pretty good in DIY I used to have E320 2003 and learned oil, transmission fluid, breaks, belt so I can do those maintenances
4) Any known defect which I should know
5) Or should I go for Lexus LS
I heard 2007 S class has some pully problem made of low material or a single gear rather double gear for the chain.
Note I am planning to keep it for the next 10 years. Compared to Acura is the maintenance is the same..
Sid
Based on your budget, you can only afford a Honda or Toyota.
Of course you might get lucky, and buy a decade-plu old, budget priced, high mileage car that's never going to have a major problem. If you have that kind of luck, you would be better off sinking that $16K into lottery tickets, then you can buy several new S650s to keep in rotation.
If you have your mind set on a 2007-2009 s-class, you'll probably pay around $10k for it. Look for an example with no or very few dash warning lights. Ideally, you'll want a low mileage car but something with 100k on it isn't the end of the world. It's probably a good idea to stay away from cars with 200k+. Take the car to a shop and have the appropriate service interval performed. It will vary depending on mileage. You can have them give an overall inspection, too. Also, keep some money in your bank account for unexpected things.
