Aux input on the W221 chassis option?
Old May 17, 2020 | 07:57 PM
theyellowbanna's Avatar
2008 S63 AMG, 2013 SL63 AMG p30, 2005 SL65 AMG, 2004 CL55 AMG
Hello,
From what I've read posted below there is a hidden aux port behind the panel in the glove box the 208 chassis. Is this option also present on the w221 chassis? I'm planning on picking up a 2008 S63 AMG and would like to know from current owners if this is the same as on the 208 chassis vehicles? I'll be picking it up in about a month and from what I saw, it has the old 30pin ipod style connector which isn't useful for my needs.
https://mbworld.org/forums/c63-amg-w...aux-input.html
Thanks guys!
EDIT:
I've picked up the car, Aux input works with an RCA to 3.5 adapter to my phone, then selected AUX from the audio menu.
Last edited by theyellowbanna; Jun 13, 2020 at 05:19 PM. Reason: Added answer after picking up the car
Old May 18, 2020 | 06:23 AM
amgs63dxb's Avatar
W222, W221, W218, W211
it depends... you didn't mention which market is the car from (US/EU/JP?). In any case, if there is no AUX in the comand menu "Sound", you can enable it with SD/Xentry. Physically, the main comand socket pins 15,16,5,6, are responsible for analog input signal and once you dig up comand from the console, you will see if anything is connected there or not...
If it has ipod connector, then somebody might have added ipod adapter - you might have to remove it in order to free the aux input (I am not aware of how this adapter interfaces with the comand, just guessing it uses analog aux with some controls input via CAN).
Old May 18, 2020 | 12:50 PM
WHPH28's Avatar
Depends on the weather
This is what I have in mine. I can plug my phone in to it or any device works with a 3.5mm jack when I put it on Aux.
Old May 18, 2020 | 01:48 PM
amgs63dxb's Avatar
sweet. Any chance you could share what module is it? Is it some form of OEM $300 + labor add on or an aftermarket mod?
Old May 18, 2020 | 01:54 PM
WHPH28's Avatar
It's OEM. I am not sure on the module part # but the the cable is mercedes part# B67824578. That may help you in finding the module #.
Old Aug 12, 2021 | 09:48 AM
S G's Avatar
S G
S class
How can I get a cable like that?
Send a link if you can for buying this cable online.
Old Aug 12, 2021 | 05:40 PM
BOTUS's Avatar
S500
the examples shown above are the facelift car... they have a different (very similar apperance) system, that is much closer to the modern world
2005 to 2009 was the NTG3.0 system
2010 to 2013 was the NTG3.5 system
back then this was the solution for aux input
https://mbworld.org/forums/s-class-w...questions.html
now they do better stuff you should probably fit this
https://mbworld.org/forums/s-class-w...y-my-w221.html
